Streams and Parameters
  • August 22, 2014
  • 16 replies
  • 6149 views
I have a few questions I'm hoping to get some help with:
  1. Playing around with streams and would like to know how to retrieve database values from a table and store it into a stream. I suspect I would need some form of Timer Service to constantly query for values. I would then use those values in a chart between certain time ranges.
2. How would I pass values to a contained mashup that is dynamically bound?
Thanks.
victorgan1-VisitorAuthor
I'm still having trouble with these two questions. Are these possible to perform within ThingWorx?
Any help would be appreciated. Thanks.
Victor,
What is your reason for wanting to store this data into a Stream?
To answer your second question, you'll do the following:
  • Bind inputs to each Mashup Parameter.
  • Remove the Mashup you set in step 2 and repeat steps 2-4 for each Mashup.
  • Once you're done, remove the Mashup you set in step 2 and verify that the Mashup is still dynamically bound.
  • Setup Mashup Parameters for each Mashup you'll be displaying in the Contained Mashup widget.
Hi Adam,
Thanks, that worked for setting up parameters on a dynamically bound mashup.
For the stream, I want to set up a stream that queries and records values in a database at a set interval. In essence, if a database is not historizing the data points, be able to perform the historization within Thingworx. If there are other alternatives to the stream, please let me know.
Hi Adam,
I have followed the steps mentioned by you.
TestDBTimer has it's own
Event
, Timer, which fires at the interval you set in the Configuration section. You'll want to create a
Subscription
 to this
Event
. Since you'll be storing this data in a
Stream
, I would create a
Subscription
 to the Timer's
Event
 on the
Stream
 and
a
Services
 on the
Stream
 (which you'll call from the
Subscription
) to retrieve values from the database and add a
Stream
 entry.
What is Add a Stream entry..?
How do I check the values in the stream?
When I call the Generic service "GetStreamData"  of Stream Thing, I get only the coloumn names and not the data.Please help.
Hi Raj,
Victor wanted to query a database at a set interval and store the results in a Stream. Adding a Stream entry refers to the Services available on Streams for adding data (e.g., AddStreamEntries, AddStreamEntry). After you've added entries to the Stream, you can query the data by using Services like QueryStreamEntriesWithData.
Hi Adam,
Thanks for the comments. I have followed the below steps and still data is not picked up in stream.
  1. I have created a subscription on the stream to TestDBTimer event with time 60 secs, and snippet: me.TestDBRetrieveService()
  2. stream service TestDBRetrieveService() code snippet:  var result = Things ["TestConnectSQL"].RetrieveTestInfoData()
 I am expecting to receive the data from DB and to be added to stream. But the data from DB is not picked up in the stream.
Note: RetrieveTestInfoData()  is working properly and returning a row of DB data.
What does your actual code snippet look like that Adds the data to the Stream (besides the retrieval of your data)?
Hi Adam & PaiC,
Thanks for pointing out. The stream is working now and picking up data. I want to remove all the entries in the Stream but  only  "DeleteStreamEntry" service is available. I am able to delete only one entry corresponding to streamEntryID.kindly let me know to remove all entries in the stream.
That can be done with PurgeStreamEntries.​ You will be asked for the time interval from which all entries will be removed.
