Suddenly the AzureIoThubConnector has stopped working!!!!
  • December 9, 2016
  • 6023 views
The azureiothub connector was working corectlty, but now has stopped working!!!!
It seems not to be able to open WS in thingworx...
Here is the log of the cx-server:
18:51:55.255 [Thread-10] ERROR c.t.s.i.t.netty.NettyBytesChannel - Error while establishing websocket connection on channel com.thingworx.sdk.impl.transport.netty.NettyBytesChannel$2@795a2ee4.
java.util.concurrent.TimeoutException: Timed out waiting for response
  at com.thingworx.sdk.impl.concurrent.DeadlineFuture.notifyOfTimeout(DeadlineFuture.java:81) ~[tw-sdk-core-1.2.0.5.jar:na]
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.notifyOfTimeout(DeadlineManager.java:132) [tw-sdk-core-1.2.0.5.jar:na]
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.processDeadlines(DeadlineManager.java:78) [tw-sdk-core-1.2.0.5.jar:na]
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.run(DeadlineManager.java:47) [tw-sdk-core-1.2.0.5.jar:na]
  at java.lang.Thread.run(Thread.java:745) [na:1.8.0_92]
18:51:55.260 [Thread-10] ERROR c.t.f.i.AbstractManyPlatformWebSocketFabric - Failure while connecting to platform: endpoint=ws://localhost:8080/Thingworx/WS
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.notifyOfTimeout(DeadlineManager.java:132) ~[tw-sdk-core-1.2.0.5.jar:na]
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.processDeadlines(DeadlineManager.java:78) ~[tw-sdk-core-1.2.0.5.jar:na]
  at com.thingworx.sdk.impl.concurrent.DeadlineManager.run(DeadlineManager.java:47) ~[tw-sdk-core-1.2.0.5.jar:na]
  at java.lang.Thread.run(Thread.java:745) ~[na:1.8.0_92]
18:51:55.361 [Thread-10] ERROR c.t.s.i.t.netty.NettyBytesChannel - Error while establishing websocket connection on channel com.thingworx.sdk.impl.transport.netty.NettyBytesChannel$2@156f3d21.
I tried to:
-Reboot
-Stop the firewall
but nothing..
Can you help me Please????
Can you make a connection to http://localhost:8080/Thingworx/Composer?
mvolanti1-VisitorAuthor
Yes!
Well, we know your local instance is up, then. We're getting a timeout, so maybe the URI in the config file has a slight error. I feel like we would get an authentication error if the API key had been wiped out by an upgrade (or something like that), but it's worth making sure the appKey you're using is still in your ThingWorx instance, too. We should look at the URI configured in your azure-iot.conf file. Mine's in the /conf dir of my Azure IoT Connector app. Here's the ThingWorx section:
  transport.websockets {
        // ThingWorx platform application key
        app-key = "xxxxxxxx-005e-49ed-8d7a-xxaxxxxxxxa"
        // One or more platforms can be specified here, comma separated
        platforms = "wss://twxazuredemo.cloudapp.net:443/Thingworx/WS"
Your error trace makes me think you're not using ssl, so your platform's entry should probably look more like ws://localhost:8080/Thingworx/WS .
Let's check all that, and continue, if we don't find an issue.
