ThingWorx foundation Server 8 installation issue
  • August 7, 2017
  • 2 replies
  • 1627 views
2017-08-07 17:20:27.656+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
No flx dll files found.  Is the java.library.path set?
WIth following configuration
-Dserver -Dd64
-XX:+UseG1GC
-Dfile.encoding=UTF-8
-Djava.library.path=\webapps\Thingworx\WEB-INF\extensions
Hi Raj, this has been discussed in detail in this blog could you please give it a try, because i think you have not correctly setup your path 7.4 Thingworx does not launch due to license error in Windows
Thanks Sushant!!
