May 16, 2024 8:58 AM UTC
Thingworx installation using installer on windows MSSQL server
I am running the thingworx installer for mssql on windows. Everything goes smoothly but at the end I am getting the following error :
get a generic message: "There has been an error. foundation Installation Failed The application will exit now.
When I check the logs files did not find any solution of how to fix it.
PS. I am running the TWX 9.5.0 installer for mssql.
Do you know what is wrong in the installation process and what is the solution
May 16, 2024 11:10 AM UTC
Hello @Surya_Tiwari
I found the solution for the error. I deleted the JAVA_HOME environment variable from my system. Now the java file path is only under the PATH variable. I ran the installer again and it worked.
May 16, 2024 10:47 AM UTC
Hi @MK_10775467
Can you take a look at the below article and let us know it is working in your case or not?
https://www.ptc.com/en/support/article/CS408945
MK_1077546710-MarbleAuthorAnswer
Hello @Surya_Tiwari
May 16, 2024 11:44 AM UTC
Hi @MK_10775467  Thanks for your confirmation here, kindly mark it as a solution.
Community Moderator
May 22, 2024 11:30 AM UTC
Hello @MK_10775467,
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
