Jun 17, 2021 3:51 PM UTC
Time dependency of the anomaly detection module
I’m interested in predict anomalies in a process that works 24/7, but for training, I only have data of two days for each week, as depicts in the image below:
Considering that I have several months of data and the timestamps for each sample, is this data enough to properly train an anomaly detection model?
nsampatAnswer
Jun 17, 2021 3:59 PM UTC
@LR_9796586 ,
Thank you for posting your question to the PTC Community.
The typical suggestion for training is to have 5 full cycles of the data to obtain a good training set.
Details on this can be found in this Knowledge Article: https://www.ptc.com/en/support/article/CS248761
Should be note, Anomaly Detection has a max period of 23 hours and 59 Minutes for its monitoring, and is not capable of multi day monitoring at this time.
Neel
nsampat17-PeridotAnswer
@LR_9796586 ,
Neel
Jun 17, 2021 6:57 PM UTC
@nsampat  Regarding the max period of 24 hours does that mean that the sum of all 5 full cycles must be less than 24 hours, or that each individual cycle must be of 23h59m at much?
Jun 21, 2021 1:44 PM UTC
@LR_9796586 ,
The 5 cycles must be within the 23 hours and 59 minutes, otherwise its considered a new training window.
Ideally you would want your cycles to be periodic and cyclical, Anomaly Detection does not handle acyclical data very well.
Neel
Support
Jul 12, 2021 8:43 PM UTC
Hi @LR_9796586
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
