Tree population from database thing (InfoTable)
  • October 2, 2014
  • 792 views
So I have a database table that has a child and parent relationship and I would like to populate a tree. I have tried doing this and the tree comes back empty.
LabelField - ChildName
ValueField - ChildName
IDField - ChildName
ParentIDField - ParentName
Any thoughts?
    You should probably populate Tree with InfoTable that is based on NetworkConnection DataShape.
    to connectionType from
    TWxPSiteGreenhousePsary Contains
    Greenhouse-B4 Contains TWxPSiteGreenhousePsary
    SensorNode-02 Contains Greenhouse-B4
    Greenhouse-B5 Contains TWxPSiteGreenhousePsary
    One of my working trees has such priperties values:
    LabelField - to
    TooltipField -
    ValueField -
    IDField - to
    ParentIDField - from
    You can start with them to see if your tree is working (as far as I can see your properties are the same).
    If you are not using NetworkConnection DataShape probably you are lacking 'connectionType' in your InfoTable.
