Tunneling with ThingWorx and .net Edge SDK
  • October 13, 2017
  • 6 replies
  • 4738 views
Is there any examples, guides on this?
Rad
Best answer by supandey
For Java i can see there is an example already available with the JAVA Edge SDK download, you can see this file in the location MED-61061-CD-055_M030_Java-SDK-6-0-4-595.zip\samples\src\com\thingworx\sdk\simple\TunnelExample.java
In addition to that there's a blog out on using EMS for tunnelling Tunneling with ThingWorx and an Edge Device
Hope this'd help.
Hi Rad, not sure if you have already seen this but I believe the TunnelManager Class reference detail is covered under the section TunnelManager Class on page 57 in Edge .NET SDK Developer’s Guide Version 5.7.1
rad11-VisitorAuthor
Thanks Sushant. I wanted to see an example of either Java or .net using file uploading/downloading and Vnc usage with these SDKs.]
Rad
supandey5-Regular MemberAnswer
Hope this'd help.
rad11-VisitorAuthor
Thanks. I will try it.
