TWX 8 have trouble with unterlines in JSON
  • August 4, 2017
  • 1305 views
Hey everyone,
I made a application with MQTT communication (receiving JSON messages) on ThingWorx 7.2.
Now I working with ThingWorx 8 and use the same application, but now I get error if the JSON messages properties include a underline ( _ ).
For example I get messages like this
"temp":12.16,
"brightness":9.97,
"name":"climateSensor_3",
"humidity":62.41,
"pressure":1013,
"time":1501774027515,
"CO2_concentration":599.39 }
I the datachange subscription of the sensor I do this
me.temp = newVal.temp;
me.humidity = newVal.humidity;
me.CO2concentration = newVal.CO2_concentration;
And I get a error: Execution error in service script [climateSensor_3 Event.DataChange:Property.MQTTValue] : Wrapped java.lang.NullPointerException Cause: null
My next step was to check every property set via logger
logger.debug("set temp");
logger.debug("set humidity");
logger.debug("set CO2_concentration");
Now I get the error before the "set CO2_concentration" is logged.
I change the
to
me.CO2concentration = newVal.CO2concentration;
and change the JSON messages and everything works well.
Why ThingWorx 8 not supported underline in JSON messages? Can I change this behaviar?
Hello, David.
As far as I know that hasn't changed, and the underscore should still work. I don't know MQTT, though. Let me check and find out if there have been changes made there that might explain what you're seeing.
Thank you,
-- Craig A.
