Update Data Table
  • April 15, 2015
  • 1788 views
Hi Team,
How Can I bind data direct to Infotable from Mashup.
I'm entering data in Grid editable column from Mashup and want it to be reflected into Thing's Infotable,where I can set (change) the values accordingly?
Please assist on this.
    20-Turquoise
    April 15, 2015
    First you would need to create a Service (ex:UpdateEditedTable) with the input of type infotable" that would correspond to the datashape of your Grid. An easy way would be to run a service that gets all records from the infotable in the composer using "Test" button and "Create Datashape from Executed result"; then add the datashape to the UpdateEditedTable service. Then, in the mashup, you'll bind the EditedTable parameter from your Grid to the UpdateEditedTable service.
