Update service in Windchill Connector for Thingworx
  • June 22, 2016
  • 2 replies
  • 1378 views
Has anyone explored Update service in Windchill connector? I am having hard time finding out how to update an object in Windchill. What syntax would work for modification parameter. Any pointers..
var params = {
  modification: undefined /* STRING */,
  dataShape: undefined /* DATASHAPENAME */,
  objects: undefined /* INFOTABLE */
// result: INFOTABLE dataShape: "undefined"
var result = me.Update(params);
    Hi
    If you use the executeTask service, you can create a Windchill task that takes parameters and updates an object accordingly. Your task should be written to perform the whole update process within a single transaction.
    For passing the parameters in this case, you use the IEProperty datashape and create one row in the InfoTable for each parameter.
    Regards
    Ian
    yes I  got it working finally Ian. Thanks for replying. It was hit and trial to figure out the syntax.
    i am trying to see what all possible with update service.
    var params1 = {
        modification: "REPLACE"  /* STRING */,
      dataShape: 'preeti-epmdoc1-datashape' /* DATASHAPENAME */,
      objects: ufids /* INFOTABLE */
    thx
