Jun 12, 2026 10:11 AM UTC
Upgrade jQuery scrollintoview plugin v1.8 (2011) to latest version
The ThingWorx mashup-vendor-shared.js file is using the jQuery scrollintoview plugin v1.8 (2011), which is vulnerable. We would like to upgrade this to the latest version, but since it is bundled within ThingWorx, please advise on the recommended approach for upgrading or replacing this plugin.
Current environment:
  • jQuery: 3.7.2
  • jQuery UI: 1.14
  • jQuery Migrate: 3.5.2
abandalAnswer
Support
Jul 23, 2026 2:27 PM UTC
Hello ​@ST_14485832,
Thank you for your patience.
I received the following update from our R&D team regarding your questions and concerns:
  • A security assessment was performed on the bundled jquery.scrollintoview plugin. No publicly disclosed CVEs were identified for the bundled version of the plugin.
  • Additionally, no publicly available security advisories or known exploit information were found during the investigation.
  • A review of the implementation showed that the plugin performs only DOM traversal, viewport calculations, and scrolling operations. It does not perform dynamic code execution, script injection, network communication, deserialization, or any other operations typically associated with exploitable security vulnerabilities.
  • Based on both the implementation review and publicly available information, no exploitable security vector was identified.
  • The reported finding is considered an informational or compliance observation related to the age of the bundled third-party dependency, rather than a confirmed security vulnerability.
  • The dependency continues to be used by the legacy Mashup Runtime, and there is currently no supported customer-side workaround available.
  • Based on the findings of this investigation, no immediate remediation is required.
We hope this information helps address your concerns. If you have any additional questions, please feel free to let us know
Support
Jun 22, 2026 9:08 PM UTC
To better understand your requirement, could you please confirm the following:
  1. What is the current version of your ThingWorx?
  2. Which specific vulnerability or CVE has been identified for this plugin, and is it coming from a security scanning tool?
  3. Is the plugin actively used in your mashups, or is this more of a compliance/security flag due to its presence?
  4. Have you implemented or considered any custom extensions/widgets that depend on or override this plugin?
  5. Have there been any custom changes made to ThingWorx platform JS files in your environment
Jul 1, 2026 6:14 AM UTC
First of all, thanks for your response.
Here are updated details:
    Thingworx Version is 9.7.3 but I also observed this jquery plugin version issue on thingworx 10.0.3 version.
    • jQuery Plugin - Latest or stable version 1.9.4
    • Ladash - 4.17.1 to Latest or Stable and Secure Version 4.18.1
    References :
    https://jquery.com/download/
    https://www.npmjs.com/package/jquery.scrollintoview
    https://security.snyk.io/package/npm/lodash/4.17.21
    https://www.npmjs.com/package/lodash?activeTab=versions
    yes, it tested from a security scanning tool.
    I think its necessary in thingworx mashup-vendor-shared.js file is using the jQuery scrollintoview plugin v1.8 (2011),
    No.
    No.
Support
Jul 6, 2026 6:36 PM UTC
Hi ​@ST_14485832,
Thank you for providing the additional details.
I understand that your security scanning tool is flagging the versions of jquery.scrollintoview and lodash bundled within the ThingWorx platform. You also confirmed that the behavior is observed in both ThingWorx 9.7.3 and 10.0.3, and that no customizations have been made to the platform files.
To help evaluate the impact more accurately, could you please provide the following:
  1. Does the security scan report reference any specific CVE(s) associated with:
    • jquery.scrollintoview v1.8
    • the bundled lodash version
  2. Can you share the relevant portion of the scan report showing:
    • Severity (Critical/High/Medium/Low)
    • CVE identifier(s)
    • Vulnerability description
    • Affected file path(s)
  3. Is the scan identifying an actual vulnerability or only recommending an upgrade because newer versions are available? For example, the latest published jquery.scrollintoview package appears to be version 1.9.4, but an older version being present does not necessarily indicate a security vulnerability by itself.
If there is a confirmed CVE affecting the bundled library, please share the vulnerability details.
Support
Jun 30, 2026 6:19 PM UTC
I hope you’re doing well.
I wanted to follow up on my previous message regarding the details needed to better understand your requirement. Could you please share the requested information when you have a chance?
