Using relative links and getting &__rnd= trash parameters send trougth the url.
  • June 9, 2014
  • 910 views
I'm trying to reference a file in the FileRepository and it worked fine but adds this:
 &__rnd=0.8384068009909242
I referenced it as: ../../Thingworx/MediaEntities/noUserImage
All is good but the end parameters.
    Hi Martin,
    That "trash" is a feature! By appending it to the URL, we ensure the browser will not cache the image and the end user will see the latest version of the Media Entity. If you prefer a cleaner URL, you can uncheck the PreventCaching property of the Image widget.
    Adam
    Helo Adam:
    Thanks, somehow if you use the prevent caching property in the image widget and set the url source on the fly it may or not work.
    Thank you.
