Using SearchModelTagTerm to get a list of ThingTemplates with this tag
  • October 13, 2014
  • 1011 views
I'm trying to get an infotable of Thing Templates that have a particular model tag. I can't figure out how to define the "types" parameter so that only ThingTemplates are returned
    Hi David,
    The types parameter expects a JSON object of the following form:
      "items": ["Thing","ThingShape","ThingTemplate","DataShape","Network","ModelTagVocabulary","Mashup", "Menu","MediaEntity","StyleDefinition","StateDefinition","DataTagVocabulary","Group","User","ApplicationKey",
    "Resource","Organization","Dashboard"]
    In your case, you'd simply have an items array that contains one item, "ThingTemplate".
    Adam
    davidcor1-VisitorAuthor
    Here is the ode that I am using and it is still returning all entity types
    var myObject = new Object();
    myObject = ;
    var params = {
     term: "TrackingDeviceModelTemplate" /* STRING /,<br> types: myObject / JSON */
    var result = Resources["SearchFunctions"].SearchModelTagTerm(params);
