Version Control
  • September 3, 2014
  • 3 replies
  • 5202 views
Does Thingworx have any version control capabilities or what would be the recommended way of backing up different versions of content and restoring?
Thanks.
    Hi Victor,
    I don't know they we've settled on a recommended method of putting ThingWorx applications under source control, but we've introduced functionality in 5.0 to make this possible. From Composer,
    Import/Export
    Source Control Entities
    . This functionality is similar to a standard export, however it will create directories for each entity type (e.g.
    Things
    ThingTemplates
    , etc.) and a file for each entity. The files are exported to a
    FileRepository
     and from there, you'll need to decide how you want to get them into a version control system.
    Adam
    victorgan1-VisitorAuthor
    Hi Adam,
    I'm using version 5.0, but I don't see the option "Source Control Entities". The options I have are the "To File" and "To ThingworxStorage". Do I need to import an extension to see this option?
    Victor,
    Are you using a 5.0 SP2? I've confirmed this menu item is available in 5.0 SP2. If you're unable to upgrade at the moment, you can access this functionality as Services (available from the Snippets tab under SourceControlFunctions) to programmatically export entities for source control.
    we have been using TW 6 and we want maintain TW code (services code) into version control.Could you please help us.
    ThingWorx Applications Version Controlling with SVN can be done by using attached document.
