VirtualThing InfoTable property with DataShape using annotations
  • September 24, 2016
  • 0 replies
  • 1119 views
Greetings,
I'm working with Thingworx Edge SDK 6.0.0 and creating a VirtualThing which contains a property of type InfoTable with a known DataShape.
I've defined the DataShape using the following annotation:
@ThingworxDataShapeDefinitions(
        dataShapes = {
                @ThingworxDataShapeDefinition(name = "AnalyticsDataShape", fields = {
                        @ThingworxFieldDefinition(name = "sourceId", description = "", baseType = "STRING",  aspects = { "isPrimaryKey:true" }),
                        @ThingworxFieldDefinition(name = "anomalous", description = "", baseType = "BOOLEAN"),
                        @ThingworxFieldDefinition(name = "gauge", description = "", baseType = "NUMBER"),
                        @ThingworxFieldDefinition(name = "value", description = "", baseType = "NUMBER"),
                        @ThingworxFieldDefinition(name = "state", description = "", baseType = "STRING")
And my property as the following:
@ThingworxPropertyDefinition(
       name = "Temperature_Analytics",
       description = "corresponding property analytics",
       baseType = "INFOTABLE",
       aspects = {
                           "dataChangeType:NEVER",
                        "dataChangeThreshold:0",
                        "cacheTime:1",
                        "isPersistent:FALSE",
                        "isReadOnly:TRUE",
                        "pushType:ALWAYS",
                          "isLogged:true",
                           "dataShape:AnalyticsDataShape"
However, when i go and bind the remote properties, Thingworx says theirs an error:
"Error browsing properties. Be sure the remote device/server is connected and configured properly"
If i comment out the dataShape:AnalyticsDataShape, then the remote property shows up and i can bind it.
What am i doing wrong?
