Web shaped chart available??
  • February 24, 2017
  • 10 replies
  • 6174 views
I want to use the similar kind of chart in my project. Is this possible?? IF so, how can I get that one??
Edit: Screenshot removed due to the request from thread owner
Hi Bavithraa, exactly this is not available in out of the box ThingWorx, however if this is exactly what you need, you can create your custom widget, here's quick start guide for you : Creating a Custom Widget in ThingWorx
February 24, 2017
Ok Sushant!! thanks for the help
February 27, 2017
when i try to import "eclipse plugin for thingworx extension' getting error as
Extension must have a metadata.xml file
