What is property queueing in EMS/LSR ? How to create custom handler and set the property values in handler.lua file ? I didn't got any reference of Property Queueing in the EMS/LSR help file.
  • February 21, 2017
  • 4 replies
  • 2354 views
Aditya,
The best introduction to this is in the ThingWorx Edge MicroServer - Lua Properties and Handlers Overview article. Additional information can be found in the Defining Properties section of the ThingWorx Edge Help Center.
adikumar5-Regular MemberAuthor
Thanks Jeremy.
The first link which you sent is not the correct link i think so. Can you again please send the link ?
Sorry about that. The correct link should be:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS252792
