Where is the SDK download?
  • March 28, 2016
  • 2 replies
  • 4721 views
There seems to be some shuffling of links on the PTC downloads page.
TW is now under "PTC smart connected applications". I can find all the versions of TW up there, but no mention of the SDKs.. Where have they been moved to?
Thanks!
Gerard, the SDKs are available under the EDGE SDK section. We also have an article on the PTC Knowledge base that details the downloads we currently have.
gseq1-VisitorAuthor
Thanks, but there is no "Edge SDK" section. The KB looks outdated, unless I'm missing something.. If I click on PTC Connected Applications from the Software Downloads page... I don't see any SDK links.
The link you provided comes up with an error "According to our records, there are no products entitled to software updates."
How are you trying to access the downloads? When you login to the PTC support site, what downloads do you get under 'Download Center' or 'PTC Software Downloads'?
*Edit*
On a side note, I updated that article to reflect the new Machine Learning section.
You can also get the latest versions from the ThingWorx IoT Marketplace​ Under the 'Edge SDKs' Category
Yep, while the download is available, I believe they've not been updated to the current release. I'll check with someone on that front too.
gseq1-VisitorAuthor
Thank you for following up. Will do.
