Why the Progress Gauge is not showing in my mashup?
  • June 22, 2016
  • 5 replies
  • 2605 views
I have downloaded the Progress Gauge extension from the Marketplace and installed it. Apparently the widget can be dragged to the mashup and be configured, but when I execute the mashup nothing appears.
I am using Thingworx 7.0.
Any hint?
Thanks.
    jcollazo1-VisitorAuthor
    Hi again,
    Suddenly the widget is showed now. Weird...
    June 23, 2016
    Have you refreshed your thingworx composer after importing the extension.
    It would have worked after refreshing the composer
    Yes I did as the import process suggested. After a couple of hours working with Thingworx and a couple of composer refreshing I had already configured the old fashion Gauge when the progress gauge appeared. Strange.
