May 15, 2019 12:32 PM UTC
Beginner questions
good day!
I started to use Vuforia Studio from this May, but I have some beginner trouble.
Could you give me any support?
Q1. About the suitable situation for recognize the thingMark by iPad and Hololens.
Now I think some factor. ThingMark size or brightness and color of surrounding, angle between Thingmark and iPad or Hololens etc..
Q2. About easy to disappear the playing data.
Moving the device when playing the AR data, the playing data disappear easily.
Is this the error of data or way to playing AR data?
tmccombieAnswer
May 20, 2019 4:54 PM UTC
The ThingMark size should the same in the project as it is printed out. See our Help Center topic on printing ThingMarks here: http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FThingCodeSizing.html%23
We also have a best practices for HoloLens projects that may be helpful: http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FEyewearBestPractices.html%23
May 15, 2019 8:53 PM UTC
hi @ADLengineer
Have you experienced issues with scanning ThingMarks on your devices? The ThingMark should be on a flat surface. Once scanned, there are some factors that come into play in terms of tracking. The environment around the TM should have a lot of saliency, texture, or interesting features.
Can you provide some more detail around the playing data issue? Are you referring to playing back a sequence, or viewing IoT data?
May 16, 2019 7:26 AM UTC
Thanks for your reply!
Sorry, I'm not sure about the detail for AR data, but my experience is single 3Dmodel made by Autodesk inventor.
This model data size is about 20MB, does data size influence the stability to play the data?
And, when I printed three TMs on a paper, playing the date become unstable.
But in the situation that two TMs are not shown, I can play the data a little easily.
Is it no good to print three TMs on a paper?
I may not answer your questions, can you check my reply?
Thanks.
May 16, 2019 7:32 PM UTC
Try printing a single ThingMark on a piece of paper and putting other interesting features around it - like a phone, cup, mouse, notebook, etc. This should help stabilize the 3D model.
Data size directly influences the publish, download, and load time of the model. We suggest to keep data under 20MB. Part count and polygon count of the model will affect the frame rate and animation performance.
