Sep 21, 2021 6:36 AM UTC
Dynamic Model Change + 3D Image Change
Hi.
I am currently making a content that changes 3D models via dropdown list menu.
I followed the instructions from this link.
http://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/Intermediate_DynamicModelLoad.html
I would like to add 3D Image per model (specifically for Model Description). So basically, if i have 5 models, i should also use 5 images. But it doesnt allow me to bind 3D image to my list as it is already bind to my model-1.
Is there a way that when i choose one item from the drop down list, that the 3D model and at the same time the 3D image will change??
Thank you in advance for the help.
Sep 21, 2021 2:55 PM UTC
Hi, @Adrian_G.
here attached a simple project with demo. It is a little different approuch as @Suraj_Patil  suggested but there are many ways the achieve this functionality and this is one possible option. Because I am not sure if the assigment will work inside the json defintion /possibly it work / but did not test my self. Here the relevant code;
$scope.populateModelList = function() {
 $scope.my_json=[
 display: "Ventil_3_sequneces",
 value: "app/resources/Uploaded/Ventil_3_sequneces_publish.pvz"
 display: "Anim Door",
 value: "app/resources/Uploaded/anim_door2.pvz",
 display: "Test Assembly",
 value: "app/resources/Uploaded/test_asm.pvz"
 $scope.mapArray=[]
$scope.mapArray["app/resources/Uploaded/Ventil_3_sequneces_publish.pvz"]="app/resources/Default/vu_alert1.svg"
$scope.mapArray["app/resources/Uploaded/anim_door2.pvz"]="app/resources/Default//vu_alert2.svg"
$scope.mapArray["app/resources/Uploaded/test_asm.pvz"]="app/resources/Default//vu_alert3.svg"
$scope.view.wdg['select-1']['list'] =$scope.my_json;
$scope.valueChange = function()
//this function is called in the change evetn of the list widget
 $scope.setWidgetProp('image-1' ,'imgsrc',$scope.mapArray[$scope.view.wdg['select-1']['value']]);
$scope.$on('$ionicView.afterEnter', function() {$scope.populateModelList();
 $scope.allWidgetToConsole();
Sep 21, 2021 8:18 AM UTC
yes its possible by using same code u mentioned in ur link by just hide/show command line used in javascript as below:
$scope.app.params.modelSelect = [
display: "Chessboard",
value: "app/resources/Uploaded/Chessboard.pvz"
$scope.view.wdg["3D-Image1"].visible = true
$scope.view.wdg["3D-Image2"].visible = false
$scope.view.wdg["3D-Image3"].visible = false
display: "Blue Pump",
value: "app/resources/Uploaded/blue_pump.pvz"
$scope.view.wdg["3D-Image1"].visible = false
$scope.view.wdg["3D-Image2"].visible = true
display: "Fan",
value: "app/resources/Uploaded/Fan.pvz"
$scope.view.wdg["3D-Image3"].visible = true
Hi, @Adrian_G.
 $scope.my_json=[
 $scope.mapArray=[]
Adrian_G.10-MarbleAuthor
Sep 22, 2021 8:05 AM UTC
Hi guys!
@Suraj_Patil  thank you for the reply. I tried your method and it works perfectly fine.
Thank you for the code. This might be useful for other situations too.
@RolandRaytchev  Thanks. I also tried your method and it also gave me the result i wanted. I will be using ur method as this might help me lessen the code when multiple models are included.
Once again, thank you guys!
You are all the best!
