Jan 25, 2024 3:00 PM UTC
error "localhost 300: Publishing failed
Initially posted in this topic
Greetings
I know this thread is old and marked as solved. But I still get the same error message.
As mentioned, I followed the guide: created a new user, added it to a developer group, and gave the group all rights.
However, I also get the error message as an administrator.
I am able to log in and validate projects.
I can also log in to the Experience Server via View on other devices and download projects.
But when I try to publish a project, after the zip files are generated and about to upload, I get the error "localhost 300: Publishing failed. Permission was denied when uploading the project." (Translated from German to English)
I had this error once before. Deleting and reinsealing ExperianceServer and Vuforia solved that problem those days. But not this time.
Errors in the Vuforia Studio log:
[2024-01-25T14:35:27.403Z] error: [2024-01-25T14:35:27.399Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] error: [twx-studio:ESPublishClient:Banan] Response code  403
[2024-01-25T14:35:27.403Z] error: [2024-01-25T14:35:27.399Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] error: [twx-studio:ESPublishClient:Banan] Response statusText  Forbidden
[2024-01-25T14:35:27.403Z] error: [2024-01-25T14:35:27.400Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] error: [twx-studio:ESPublishClient:Banan] Response body  {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2024-01-25T14:35:27.403Z] error: [2024-01-25T14:35:27.400Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] error: [twx-studio:ESPublishClient:Banan] Response error  undefined
[2024-01-25T14:35:27.403Z] error: [2024-01-25T14:35:27.400Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] error: [twx-studio:ESPublishClient:Banan] Failed to upload to the Experience Service. undefined
[2024-01-25T14:35:27.400Z] error: [twx-studio:projectHelper] publishTask error for project Banan {"statusCode":403,"message":"{\"message\":\"Insufficient permissions to access resource\",\"errorCode\":403,\"error\":{}}"}
[2024-01-25T14:35:27.401Z] error: [twx-studio:api] Error occured while publishing project Banan {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
I hope you can help me.
Best Wishes
Jan 25, 2024 4:36 PM UTC
Hello Stefan,
 To investigate a specifc issue, it is better to open a new thread or the best is to open a new case.
To go deeper about your issue when reproducing the issue can you collect the Vuforia Experience Service output in terminal.
Best regards,
Samuel
Feb 7, 2024 12:04 PM UTC
Hey Samuel
First,  thank you for, moving this into a new thread. I should have known bather.
Sure I just created a fresh output of the Experience Service:
Your environment has been set up for using Node.js 14.18.2 (x64) and npm.
Using node from "C:\ptc.old\studio-es\nodejs\node.exe"
Node version: v14.18.2
NPM version: 6.14.15
This message should appear in the logs if stderr stream is captured
Validating command line arguments and environment variables
No configuration update is needed
ExperienceService version is 9.8.0-b1267
Log format: :remote-addr - :remote-user [:date[iso]] ":method :url HTTP/:http2-version" :status :res[content-length] ":referrer" ":user-agent" :response-time[0] ms :req[host] :req[content-length] [:request-start-datetime] :upload-file-transfer-time ms :upload-unzip-time ms :upload-irs-time ms :upload-tg-time ms
Using database handler: SQLiteHandler
Starting 'C:\ptc.old\studio-es\server.js' at 2024-02-07T11:49:23.533Z
Setting DEBUG value: vxs
 vxs Ensure store directory: C:\ptc\studio-es-store\projects +0ms
 vxs Ensure store directory: C:\ptc\studio-es-store\reps +2ms
 vxs Ensure store directory: C:\ptc\studio-es-store\upgrade +0ms
 vxs Count of files or directories in C:\ptc\studio-es-store\projects: 1 +71ms
 vxs Count of files or directories in C:\ptc\studio-es-store\upgrade: 1 +1ms
 vxs Count of files or directories in C:\ptc\studio-es-store\reps: 0 +0ms
Store for projects: C:\ptc\studio-es-store\projects
Store for reps: C:\ptc\studio-es-store\reps
Store for upgrade: C:\ptc\studio-es-store\upgrade
SQLite db file: C:\ptc\studio-es-store\db.sqlite
 vxs Database handler init resolved. undefined +195ms
In acl.init. Set synchronize timer, refresh interval (ms): 300000
=== Adding routing for root /ExperienceService
=== Adding routing for root /VuforiaExperienceService
Initializing billable event
Loading proxy configurations
1 web proxy routes created
 vxs load proxy configuration resolved. [] +12s
 vxs load Access Control Rules resolved. true +100ms
 vxs namespace init resolved undefined +6ms
Initializing metrics handler
Server is using null metrics handler
Initializing users handler
 vxs load users handler resolved. 1 +3ms
Initializing DNS-SD handler
 vxs DNS-SD handler init resolved. 1 +34ms
Initializing rolesManager
migrator transformIdMappingValuesThumbnails.js was previously executed on 2024-01-25T13:45:28.752Z
migrator obsoleteAllowAnonymousGet.js was previously executed on 2024-01-25T13:45:28.752Z
migrator allowGlobalRoles.js was previously executed on 2024-01-25T13:45:28.752Z
migrator appFileSize.js was previously executed on 2024-01-25T13:45:28.772Z
migrator dateFormatUpgrade.js was previously executed on 2024-01-25T13:45:28.772Z
 vxs upgrade resolved undefined +308ms
 vxs ## Routes report begins:
 vxs # |index | method | route | middleware
 vxs --|----------| -------- | ---------------------------------------- | ----------
 vxs 1| | | / | logger http1OnlyCompression namespaceMiddleware initialize helmet jsonParser urlencodedParser cookieParser <anonymous> <anonymous> <anonymous> <anonymous>
 vxs 2|2 | get | /ExperienceService/ping/ | <anonymous>
 vxs 3|3 | get | /ExperienceService/metrics/ | metrics
 vxs 4|6 | | /thingworx/ | proxyMiddleware
 vxs 5|12 | | /ExperienceService/viewCommandHost/ | <anonymous>
 vxs 6|12,1 | | /ExperienceService/capabilities/:capability(mtg|itg|amtg)/ | authenticate canAccept capabilitiesMdw
 vxs 7|12,2 | post | /ExperienceService/vuforia/model-target/signatures/ | authenticate aclMdw getSignature
 vxs 8|12,2,,3 | options | /ExperienceService/vuforia/model-target/signatures/ | options
 vxs 9|12,2,,4 | | /ExperienceService/vuforia/model-target/signatures/ | sendMethodNotAllowed
 vxs 10|12,3 | | /ExperienceService/content/:store/:name/ | <anonymous>
 vxs 11|12,4 | | /ExperienceService/content/reps/:name/ | <anonymous>
 vxs 12|12,5 | get | /ExperienceService/content/projects/:appName/public/*/ | sendFile
 vxs 13|12,6 | get | /ExperienceService/content/projects/:name/ | acceptsZipFile publicProjectFilter useNamespaceStore offlineContent
 vxs 14|12,7 | get | /ExperienceService/content/projects/:name/ | acceptsZipFile useNamespaceStore authenticate aclMdw middleware offlineContent
 vxs 15|12,8 | get | /ExperienceService/content/projects/:name/*/ | publicProjectFilter useResource useNamespaceStore serveStatic resourceNotFound
 vxs 16|12,8,1 | get | /ExperienceService/content/projects/:name/access/ | skipAcceptNonJson authenticate aclMdw getAccess
 vxs 17|12,8,2 | put | /ExperienceService/content/projects/:name/access/ | authenticate aclMdw updateAccess
 vxs 18|12,9 | get | /ExperienceService/content/projects/:appName?/ | authenticate aclMdw conditionalListProjects
 vxs 19|12,10 | | /ExperienceService/content/projects/ | useNamespaceStore authenticate aclMdw middleware serveStatic
 vxs 20|12,15 | options | /ExperienceService/content/:store(projects|reps)/:archive?/ | authenticate aclMiddleware options
 vxs 21|12,15,1 | post | /ExperienceService/content/:store(projects)/ | authenticate aclMdw doUpload
 vxs 22|12,15,2 | post | /ExperienceService/content/:store(reps)/ | authenticate aclMdw doUpload
 vxs 23|12,15,3 | put | /ExperienceService/content/:store(projects)/:archive/ | authenticate aclMiddleware doUpload
 vxs 24|12,15,4 | put | /ExperienceService/content/:store(reps)/:archive/ | authenticate aclMiddleware doUpload
 vxs 25|12,15,5 | delete | /ExperienceService/content/:store(reps)/:contentName/ | authenticate aclMiddleware deleteApp
 vxs 26|12,15,6 | delete | /ExperienceService/content/:store(projects)/:contentName/ | authenticate aclMiddleware deleteApp
 vxs 27|12,15,7 | get | /ExperienceService/content/reps/:name/*/ | publicRepresentationFilter blockViewIfLimitReached useNamespaceStore serveStatic resourceNotFound
 vxs 28|12,15,7,1 | get | /ExperienceService/content/reps/:name/access/ | skipAcceptNonJson authenticate orMiddleware getAccess
 vxs 29|12,15,7,2 | put | /ExperienceService/content/reps/:name/access/ | authenticate orMiddleware updateAccess
 vxs 30|12,15,7,3 | get | /ExperienceService/content/reps/:name?/ | authenticate aclPassThroughMdw listReps
 vxs 31|12,15,7,4 | get | /ExperienceService/content/reps/*/ | authenticate orMiddleware blockViewIfLimitReached useNamespaceStore serveStatic
 vxs 32|12,16 | get | /ExperienceService/id-resolution/resolutions/ | getResolutions
 vxs 33|12,16,1 | | /ExperienceService/id-resolution/resolutions/ | sendMethodNotAllowed
 vxs 34|12,16,2 | post | /ExperienceService/id-resolution/mappings/ | authenticate aclMdw requestHandler
 vxs 35|12,16,3 | put | /ExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw requestHandler
 vxs 36|12,16,4 | delete | /ExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw requestHandler
 vxs 37|12,16,5 | options | /ExperienceService/id-resolution/mappings/:id?/ | authenticate aclMdw options
 vxs 38|12,16,6 | get | /ExperienceService/id-resolution/mappings/:id?/ | authenticate aclMdw requestHandler
 vxs 39|12,16,7 | | /ExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw sendMethodNotAllowed
 vxs 40|12,16,8 | | /ExperienceService/id-resolution/mappings/ | authenticate aclMdw sendMethodNotAllowed
 vxs 41|12,16,9 | | /ExperienceService/id-resolution/ids*/ | authenticate thisRouteIsGone
 vxs 42|12,16,10 | post | /ExperienceService/id-resolution/admin/batch/mappings/ | authenticate aclMdw importMappings
 vxs 43|12,16,11 | | /ExperienceService/id-resolution/admin/batch/mappings/ | authenticate aclMdw sendMethodNotAllowed
 vxs 44|12,16,12 | get | /ExperienceService/id-resolution/admin/mapping/issues/ | authenticate aclMdw getMappingIssues
 vxs 45|12,16,13 | | /ExperienceService/id-resolution/admin/mapping/issues/ | authenticate aclMdw sendMethodNotAllowed
 vxs 46|12,17 | get | /ExperienceService/properties/ | authenticate aclMdw getProperties
 vxs 47|12,17,1 | get | /ExperienceService/properties/:propertyName/ | authenticate aclMdw getProperties
 vxs 48|12,17,2 | | /ExperienceService/properties/ | authenticate aclMdw sendMethodNotAllowed
 vxs 49|12,18 | | /ExperienceService/admin/ | authenticate aclMdw <anonymous>
 vxs 50|12,18,2 | get | /ExperienceService/admin/logs/debug/ | nonAdminQuickNotFound <anonymous>
 vxs 51|12,18,3 | put | /ExperienceService/admin/logs/debug/ | nonAdminQuickNotFound <anonymous>
 vxs 52|12,18,4 | get | /ExperienceService/admin/logs/ | nonAdminQuickNotFound logs
 vxs 53|12,18,6 | get | /ExperienceService/admin/proxies/:id/ | <anonymous>
 vxs 54|12,18,6,1 | put | /ExperienceService/admin/proxies/:id/ | <anonymous>
 vxs 55|12,18,6,2 | options | /ExperienceService/admin/proxies/:id/ | options
 vxs 56|12,18,6,3 | | /ExperienceService/admin/proxies/:id/ | sendMethodNotAllowed
 vxs 57|12,18,7 | get | /ExperienceService/admin/settings/:category/:name/ | <anonymous>
 vxs 58|12,18,7,1 | put | /ExperienceService/admin/settings/:category/:name/ | <anonymous>
 vxs 59|12,18,7,2 | options | /ExperienceService/admin/settings/:category/:name/ | options
 vxs 60|12,18,7,3 | | /ExperienceService/admin/settings/:category/:name/ | sendMethodNotAllowed
 vxs 61|12,18,8 | get | /ExperienceService/admin/usage/viewcount/:store(reps)/ | getCount
 vxs 62|12,18,8,1 | options | /ExperienceService/admin/usage/viewcount/:store(reps)/ | options
 vxs 63|12,18,8,2 | | /ExperienceService/admin/usage/viewcount/:store(reps)/ | sendMethodNotAllowed
 vxs 64|12,19 | get | /ExperienceService/username/ | authWithSelfRegistrationOption <anonymous>
 vxs 65|12,19,1 | get | /ExperienceService/ | <anonymous>
 vxs 66|12,20 | | /ExperienceService/ui/ | <anonymous>
 vxs 67|12,21 | | /ExperienceService/compliance/ | acceptsJson authenticate aclMdw
 vxs 68|12,21,3 | get | /ExperienceService/compliance/views/ | <anonymous>
 vxs 69|12,21,3,1 | options | /ExperienceService/compliance/views/ | options
 vxs 70|12,21,3,2 | | /ExperienceService/compliance/views/ | sendMethodNotAllowed
 vxs 71|12,21,4 | get | /ExperienceService/compliance/users/ | <anonymous>
 vxs 72|12,21,4,1 | options | /ExperienceService/compliance/users/ | options
 vxs 73|12,21,4,2 | | /ExperienceService/compliance/users/ | sendMethodNotAllowed
 vxs 74|13 | | /VuforiaExperienceService/viewCommandHost/ | <anonymous>
 vxs 75|13,1 | | /VuforiaExperienceService/capabilities/:capability(mtg|itg|amtg)/ | authenticate canAccept capabilitiesMdw
 vxs 76|13,2 | post | /VuforiaExperienceService/vuforia/model-target/signatures/ | authenticate aclMdw getSignature
 vxs 77|13,2,,3 | options | /VuforiaExperienceService/vuforia/model-target/signatures/ | options
 vxs 78|13,2,,4 | | /VuforiaExperienceService/vuforia/model-target/signatures/ | sendMethodNotAllowed
 vxs 79|13,3 | | /VuforiaExperienceService/content/:store/:name/ | <anonymous>
 vxs 80|13,4 | | /VuforiaExperienceService/content/reps/:name/ | <anonymous>
 vxs 81|13,5 | get | /VuforiaExperienceService/content/projects/:appName/public/*/ | sendFile
 vxs 82|13,6 | get | /VuforiaExperienceService/content/projects/:name/ | acceptsZipFile publicProjectFilter useNamespaceStore offlineContent
 vxs 83|13,7 | get | /VuforiaExperienceService/content/projects/:name/ | acceptsZipFile useNamespaceStore authenticate aclMdw middleware offlineContent
 vxs 84|13,8 | get | /VuforiaExperienceService/content/projects/:name/*/ | publicProjectFilter useResource useNamespaceStore serveStatic resourceNotFound
 vxs 85|13,8,1 | get | /VuforiaExperienceService/content/projects/:name/access/ | skipAcceptNonJson authenticate aclMdw getAccess
 vxs 86|13,8,2 | put | /VuforiaExperienceService/content/projects/:name/access/ | authenticate aclMdw updateAccess
 vxs 87|13,9 | get | /VuforiaExperienceService/content/projects/:appName?/ | authenticate aclMdw conditionalListProjects
 vxs 88|13,10 | | /VuforiaExperienceService/content/projects/ | useNamespaceStore authenticate aclMdw middleware serveStatic
 vxs 89|13,15 | options | /VuforiaExperienceService/content/:store(projects|reps)/:archive?/ | authenticate aclMiddleware options
 vxs 90|13,15,1 | post | /VuforiaExperienceService/content/:store(projects)/ | authenticate aclMdw doUpload
 vxs 91|13,15,2 | post | /VuforiaExperienceService/content/:store(reps)/ | authenticate aclMdw doUpload
 vxs 92|13,15,3 | put | /VuforiaExperienceService/content/:store(projects)/:archive/ | authenticate aclMiddleware doUpload
 vxs 93|13,15,4 | put | /VuforiaExperienceService/content/:store(reps)/:archive/ | authenticate aclMiddleware doUpload
 vxs 94|13,15,5 | delete | /VuforiaExperienceService/content/:store(reps)/:contentName/ | authenticate aclMiddleware deleteApp
 vxs 95|13,15,6 | delete | /VuforiaExperienceService/content/:store(projects)/:contentName/ | authenticate aclMiddleware deleteApp
 vxs 96|13,15,7 | get | /VuforiaExperienceService/content/reps/:name/*/ | publicRepresentationFilter blockViewIfLimitReached useNamespaceStore serveStatic resourceNotFound
 vxs 97|13,15,7,1 | get | /VuforiaExperienceService/content/reps/:name/access/ | skipAcceptNonJson authenticate orMiddleware getAccess
 vxs 98|13,15,7,2 | put | /VuforiaExperienceService/content/reps/:name/access/ | authenticate orMiddleware updateAccess
 vxs 99|13,15,7,3 | get | /VuforiaExperienceService/content/reps/:name?/ | authenticate aclPassThroughMdw listReps
 vxs 100|13,15,7,4 | get | /VuforiaExperienceService/content/reps/*/ | authenticate orMiddleware blockViewIfLimitReached useNamespaceStore serveStatic
 vxs 101|13,16 | get | /VuforiaExperienceService/id-resolution/resolutions/ | getResolutions
 vxs 102|13,16,1 | | /VuforiaExperienceService/id-resolution/resolutions/ | sendMethodNotAllowed
 vxs 103|13,16,2 | post | /VuforiaExperienceService/id-resolution/mappings/ | authenticate aclMdw requestHandler
 vxs 104|13,16,3 | put | /VuforiaExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw requestHandler
 vxs 105|13,16,4 | delete | /VuforiaExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw requestHandler
 vxs 106|13,16,5 | options | /VuforiaExperienceService/id-resolution/mappings/:id?/ | authenticate aclMdw options
 vxs 107|13,16,6 | get | /VuforiaExperienceService/id-resolution/mappings/:id?/ | authenticate aclMdw requestHandler
 vxs 108|13,16,7 | | /VuforiaExperienceService/id-resolution/mappings/:id/ | authenticate aclMdw sendMethodNotAllowed
 vxs 109|13,16,8 | | /VuforiaExperienceService/id-resolution/mappings/ | authenticate aclMdw sendMethodNotAllowed
 vxs 110|13,16,9 | | /VuforiaExperienceService/id-resolution/ids*/ | authenticate thisRouteIsGone
 vxs 111|13,16,10 | post | /VuforiaExperienceService/id-resolution/admin/batch/mappings/ | authenticate aclMdw importMappings
 vxs 112|13,16,11 | | /VuforiaExperienceService/id-resolution/admin/batch/mappings/ | authenticate aclMdw sendMethodNotAllowed
 vxs 113|13,16,12 | get | /VuforiaExperienceService/id-resolution/admin/mapping/issues/ | authenticate aclMdw getMappingIssues
 vxs 114|13,16,13 | | /VuforiaExperienceService/id-resolution/admin/mapping/issues/ | authenticate aclMdw sendMethodNotAllowed
 vxs 115|13,17 | get | /VuforiaExperienceService/properties/ | authenticate aclMdw getProperties
 vxs 116|13,17,1 | get | /VuforiaExperienceService/properties/:propertyName/ | authenticate aclMdw getProperties
 vxs 117|13,17,2 | | /VuforiaExperienceService/properties/ | authenticate aclMdw sendMethodNotAllowed
 vxs 118|13,18 | | /VuforiaExperienceService/admin/ | authenticate aclMdw <anonymous>
 vxs 119|13,18,2 | get | /VuforiaExperienceService/admin/logs/debug/ | nonAdminQuickNotFound <anonymous>
 vxs 120|13,18,3 | put | /VuforiaExperienceService/admin/logs/debug/ | nonAdminQuickNotFound <anonymous>
 vxs 121|13,18,4 | get | /VuforiaExperienceService/admin/logs/ | nonAdminQuickNotFound logs
 vxs 122|13,18,6 | get | /VuforiaExperienceService/admin/proxies/:id/ | <anonymous>
 vxs 123|13,18,6,1 | put | /VuforiaExperienceService/admin/proxies/:id/ | <anonymous>
 vxs 124|13,18,6,2 | options | /VuforiaExperienceService/admin/proxies/:id/ | options
 vxs 125|13,18,6,3 | | /VuforiaExperienceService/admin/proxies/:id/ | sendMethodNotAllowed
 vxs 126|13,18,7 | get | /VuforiaExperienceService/admin/settings/:category/:name/ | <anonymous>
 vxs 127|13,18,7,1 | put | /VuforiaExperienceService/admin/settings/:category/:name/ | <anonymous>
 vxs 128|13,18,7,2 | options | /VuforiaExperienceService/admin/settings/:category/:name/ | options
 vxs 129|13,18,7,3 | | /VuforiaExperienceService/admin/settings/:category/:name/ | sendMethodNotAllowed
 vxs 130|13,18,8 | get | /VuforiaExperienceService/admin/usage/viewcount/:store(reps)/ | getCount
 vxs 131|13,18,8,1 | options | /VuforiaExperienceService/admin/usage/viewcount/:store(reps)/ | options
 vxs 132|13,18,8,2 | | /VuforiaExperienceService/admin/usage/viewcount/:store(reps)/ | sendMethodNotAllowed
 vxs 133|13,19 | get | /VuforiaExperienceService/username/ | authWithSelfRegistrationOption <anonymous>
 vxs 134|13,19,1 | get | /VuforiaExperienceService/ | <anonymous>
 vxs 135|13,20 | | /VuforiaExperienceService/ui/ | <anonymous>
 vxs 136|13,21 | | /VuforiaExperienceService/compliance/ | acceptsJson authenticate aclMdw
 vxs 137|13,21,3 | get | /VuforiaExperienceService/compliance/views/ | <anonymous>
 vxs 138|13,21,3,1 | options | /VuforiaExperienceService/compliance/views/ | options
 vxs 139|13,21,3,2 | | /VuforiaExperienceService/compliance/views/ | sendMethodNotAllowed
 vxs 140|13,21,4 | get | /VuforiaExperienceService/compliance/users/ | <anonymous>
 vxs 141|13,21,4,1 | options | /VuforiaExperienceService/compliance/users/ | options
 vxs 142|13,21,4,2 | | /VuforiaExperienceService/compliance/users/ | sendMethodNotAllowed +6ms
 vxs ## Routes report ends +11ms
Setting DEBUG value: undefined
Enabled debug namespaces:
Disabled debug namespaces: verb.vxs:apid.rt verbose.vxs:acl verbose.vxs:aclDbAclDbBackend verbose.vxs:auth.tokenManager verbose.vxs:cds.metadata verbose.vxs:cds.unzip verbose.vxs:irs.search verbose.vxs:proxy vxs vxs:access.deleteAppListener vxs:acl vxs:acl.TwxRolesSync vxs:acl.pkg vxs:acl.roleMembers vxs:aclDbAclDbBackend vxs:admin.domains vxs:admin.settings vxs:admin.users vxs:app vxs:auth vxs:auth.tokenManager vxs:auth.twx vxs:billable vxs:cds vxs:cds.delete vxs:cds.download vxs:cds.list vxs:cds.listReps vxs:cds.metadata vxs:cds.options vxs:cds.unzip vxs:cors vxs:cryptoHelper vxs:device vxs:digest vxs:dns vxs:fixtimer vxs:irs.delete vxs:irs.get vxs:irs.get.issues vxs:irs.import vxs:irs.options vxs:irs.search vxs:irs.search vxs:irs.upload vxs:irs.utils vxs:limitshelper vxs:logs vxs:metrics.usage vxs:mtg vxs:ns vxs:ns.acl vxs:ns.settingsLoader vxs:performance-metrics vxs:project vxs:project-access vxs:proxy vxs:proxymgr vxs:pxapi vxs:rep vxs:rep-access vxs:repViewedEvent vxs:resource-access vxs:roles vxs:roles.mgr vxs:security vxs:sql vxs:sql.scriptfilter vxs:tenants vxs:tg vxs:tg.mm vxs:tg.util vxs:upgrade vxs:upgrade.migrators.mbu vxs:upgrade.migrators.metrics vxs:upgrade.migrators.mpp vxs:upgrade.migrators.ss vxs:upgrade.migrators.tg vxs:usageMonitor vxs:userRegistration vxs:vdp-model-target
Starting server now ...
1 websocket proxies created
Server is using DESKTOP-2MJUJ82.local as the defaultDomainName
WARNING >>> Server is running in INSECURE mode
Server is using the 'all' routingMode
Namespaces Disabled
Server startup completed in 14045 ms
HTTP Listening on port 2019
::ffff:127.0.0.1 - - [2024-02-07T11:53:02.633Z] "GET /ExperienceService/.well-known/oauth-config HTTP/1.1" 404 49 "-" "got (https://github.com/sindresorhus/got)" 19 ms 127.0.0.1:2019 - [2024-02-07T11:53:02.592Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - - [2024-02-07T11:53:02.666Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 4 ms 127.0.0.1:2019 - [2024-02-07T11:53:02.662Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - - [2024-02-07T11:53:02.765Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms 127.0.0.1:2019 - [2024-02-07T11:53:02.764Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - - [2024-02-07T11:53:02.808Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 2 ms 127.0.0.1:2019 - [2024-02-07T11:53:02.806Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - - [2024-02-07T11:53:03.107Z] "GET /ExperienceService/viewCommandHost HTTP/1.1" 200 24 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms 127.0.0.1:2019 - [2024-02-07T11:53:03.106Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - - [2024-02-07T11:53:49.835Z] "GET /ExperienceService/username HTTP/1.1" 401 - "-" "got (https://github.com/sindresorhus/got)" 1 ms 127.0.0.1:2019 - [2024-02-07T11:53:49.833Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - Administrator [2024-02-07T11:54:06.209Z] "GET /ExperienceService/username HTTP/1.1" 200 13 "-" "got (https://github.com/sindresorhus/got)" 1160 ms 127.0.0.1:2019 - [2024-02-07T11:54:05.048Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - Administrator [2024-02-07T11:54:06.225Z] "GET /ExperienceService/capabilities/omtg HTTP/1.1" 404 49 "-" "got (https://github.com/sindresorhus/got)" 1 ms 127.0.0.1:2019 - [2024-02-07T11:54:06.224Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - Administrator [2024-02-07T11:54:06.238Z] "GET /ExperienceService/capabilities/itg HTTP/1.1" 200 47 "-" "got (https://github.com/sindresorhus/got)" 1 ms 127.0.0.1:2019 - [2024-02-07T11:54:06.237Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - Administrator [2024-02-07T11:54:06.249Z] "GET /ExperienceService/capabilities/mtg HTTP/1.1" 200 16 "-" "got (https://github.com/sindresorhus/got)" 1 ms 127.0.0.1:2019 - [2024-02-07T11:54:06.248Z] - ms - ms - ms - ms
::ffff:127.0.0.1 - Administrator [2024-02-07T11:54:08.761Z] "POST /ExperienceService/content/projects?replace=true HTTP/1.1" 403 84 "-" "got (https://github.com/sindresorhus/got)" 15 ms 127.0.0.1:2019 2301697 [2024-02-07T11:54:08.745Z] - ms - ms - ms - ms
 And adittional the Protokoll of Fuvoria Studio (Last and this time)
[2024-01-25T14:32:30.976Z] info: ==== Studio.exe 9.16.1.0 ====
[2024-01-25T14:32:31.042Z] info: Status Message: Vorbereitung läuft...
[2024-01-25T14:32:31.042Z] info: Starting node.exe "C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\index.js" --writableDistDir="C:\Users\vuforia\AppData\Local\VuforiaStudio\dist"
[2024-01-25T14:32:31.042Z] info: 	NODE_PATH: C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules
[2024-01-25T14:32:46.223Z] info: [twx-studio:index] Studio Version 9.16.1.0
[2024-01-25T14:32:46.249Z] info: [twx-studio:initializer] Node version: 18.18.2
[2024-01-25T14:32:46.249Z] info: [twx-studio:initializer] studio launched with the following arguments: {"_":[],"writableDistDir":"C:\\Users\\vuforia\\AppData\\Local\\VuforiaStudio\\dist","$0":"dist\\server\\index.js"}
[2024-01-25T14:32:46.250Z] info: [twx-studio:initializer] studio dir: C:\Users\vuforia\Documents\VuforiaStudio , home dir: C:\Users\vuforia\Documents
[2024-01-25T14:32:46.256Z] info: [twx-studio:builderSettingService] C:\Users\vuforia\Documents\VuforiaStudio\builder-settings.json was not found, creating it now
[2024-01-25T14:32:46.258Z] info: [twx-studio:configSettingService] C:\ProgramData\VuforiaStudio\config-settings.json was not found, using default config-settings
[2024-01-25T14:32:52.405Z] info: [twx-studio:index] Starting HTTP server...
[2024-01-25T14:32:55.059Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 9.16.1.0
[2024-01-25T14:32:58.335Z] info: [twx-studio:upgrade:StudioSample3DImport] Upgrading project
[2024-01-25T14:32:58.792Z] info: [twx-studio:upgrade:StudioSampleEyewear] Upgrading project
[2024-01-25T14:32:58.923Z] info: [twx-studio:upgrade:StudioSampleSpatial] Upgrading project
[2024-01-25T14:32:59.126Z] info: [twx-studio:upgrade:StudioSampleQuadcopter] Upgrading project
[2024-01-25T14:32:59.144Z] error: [winston] Unknown logger level: Update the binding in view
[2024-01-25T14:33:08.410Z] info: [twx-studio:upgrade:StudioSampleSpatial] Building ves-ar-extension app:
[2024-01-25T14:33:12.482Z] info: [twx-studio:upgrade:StudioSampleQuadcopter] Building ves-ar-extension app:
[2024-01-25T14:33:12.498Z] info: [twx-studio:upgrade:StudioSampleEyewear] Building ves-ar-extension app:
[2024-01-25T14:33:12.529Z] info: [twx-studio:upgrade:StudioSample3DImport] Building ves-ar-extension app:
[2024-01-25T14:33:16.415Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\StudioSampleQuadcopter\upgrade.log
[2024-01-25T14:33:16.418Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\StudioSampleSpatial\upgrade.log
[2024-01-25T14:33:16.419Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\StudioSampleEyewear\upgrade.log
[2024-01-25T14:33:16.561Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\StudioSample3DImport\upgrade.log
[2024-01-25T14:33:17.917Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:33:18.006Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:33:18.261Z] info: [twx-studio:index] Studio Ready http://localhost:3000
[2024-01-25T14:33:19.340Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
::1 - d6fc3fda-137e-4c0c-b984-6c4927c87e08 [2024-01-25T14:33:23.480Z] "GET /api/projectTemplates HTTP/1.1" 304 "http://localhost:3000/home" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 30 ms undefined b19a1780-bb8e-11ee-a0c6-25a6b44b12ff
[2024-01-25T14:33:23.763Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:33:24.200Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:33:25.487Z] info: [twx-studio:studio-log] Debug logging disabled
[2024-01-25T14:33:26.380Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:34:42.427Z] info: [twx-studio:projectSettings] fileName "3D_Eyewear_-_Default" did not match location "Banan" for project named "3D Eyewear - Default". The fileName and name will be changed to match location.
[2024-01-25T14:34:42.440Z] info: [twx-studio:upgrade:Banan] Upgrading project
[2024-01-25T14:34:45.972Z] info: [twx-studio:upgrade:Banan] Building ves-ar-extension app:
[2024-01-25T14:34:47.190Z] info: [twx-studio:auth:oauthHandler] Server is not OAuth http://127.0.0.1:2019
[2024-01-25T14:34:48.042Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\Banan\upgrade.log
[2024-01-25T14:34:48.044Z] info: [twx-studio:projectHelper] Creating ves-ar-extension app: Banan
::1 - d6fc3fda-137e-4c0c-b984-6c4927c87e08 [2024-01-25T14:34:48.056Z] "POST /api/project HTTP/1.1" 200 20 "http://localhost:3000/home" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 5791 ms 125 undefined ecd1f99c-a279-4c74-997b-36e33dd6a214
[2024-01-25T14:34:48.083Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
::1 - d6fc3fda-137e-4c0c-b984-6c4927c87e08 [2024-01-25T14:34:48.536Z] "GET /api/projectTemplates HTTP/1.1" 304 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 5 ms undefined e450ba30-bb8e-11ee-a0c6-25a6b44b12ff
[2024-01-25T14:34:48.715Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:34:48.732Z] info: [twx-studio:upgrade:Banan] Upgrading project
[2024-01-25T14:34:49.240Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-01-25T14:34:52.520Z] info: [twx-studio:upgrade:Banan] Building ves-ar-extension app:
[2024-01-25T14:34:53.663Z] info: [twx-studio:upgradeProject] Upgrade log saved to C:\Users\vuforia\Documents\VuforiaStudio\Projects\Banan\upgrade.log
::1 - d6fc3fda-137e-4c0c-b984-6c4927c87e08 [2024-01-25T14:34:54.872Z] "GET /api/switch HTTP/1.1" 401 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 4 ms undefined e8178630-bb8e-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:34:54.876Z] "GET /api/switch HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined e81897a0-bb8e-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:34:54.913Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 12 ms undefined 0ffbbd5c-10ae-47cf-878e-c46b80c31dbb
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:34:54.975Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 22 ms undefined 5c4c2a69-a063-4045-a9a8-2ceadfebeb6a
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:34:55.033Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 7 ms undefined 65f072e5-0bda-4bde-a6f2-bee4665ee677
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:34:55.037Z] "GET /ExperienceService/viewCommandHost HTTP/1.1" 200 24 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 9 ms undefined df1491e3-a105-41a7-b04d-150b890fb5df
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:09.216Z] "GET /api/server/authorize HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined f0a4daf0-bb8e-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:09.229Z] "POST /api/server/token HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 5 ms 0 undefined f0a61370-bb8e-11ee-a0c6-25a6b44b12ff
[2024-01-25T14:35:11.609Z] info: [twx-studio:projectHelper] Building ves-ar-extension app: Banan
[2024-01-25T14:35:12.700Z] info: [twx-studio:projectSettings] Notify preview windows: private-room-Banan
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:12.703Z] "POST /api/project/resource/save HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 3466 ms 3842 undefined f0a7c120-bb8e-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:12.743Z] "GET /api/switch HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined f2bee150-bb8e-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:12.773Z] "POST /api/publish/ HTTP/1.1" 401 37 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 24 ms 8338 undefined 6c6ee85d-4b9e-439a-9510-fd1b421ae24a
[2024-01-25T14:35:25.377Z] info: [twx-studio:SaasUtils] Saas=false for server http://127.0.0.1:2019
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:35:25.390Z] "POST /api/publish/ HTTP/1.1" 200 15 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 326 ms 8338 undefined 6c6ee85d-4b9e-439a-9510-fd1b421ae24a
[2024-01-25T14:35:25.381Z] info: [2024-01-25T14:35:25.393Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] warn: [twx-studio:ESPublishClient:Banan] Error retrieving ES capability: omtg 404 Not Found
[2024-01-25T14:35:25.420Z] info: [2024-01-25T14:35:25.417Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] info: [twx-studio:ESPublishClient:Banan] Zipping C:\Users\vuforia\Documents\VuforiaStudio\Projects\Banan\dist
[2024-01-25T14:35:26.093Z] info: [2024-01-25T14:35:26.090Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] info: [twx-studio:ESPublishClient:Banan] filter out entry: extensions/js/libthingview_wasm.wasm
[2024-01-25T14:35:27.344Z] info: [2024-01-25T14:35:27.340Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] info: [twx-studio:ESPublishClient:Banan] zip size 2301418 bytes (approximately 2 MB)
[2024-01-25T14:35:27.344Z] info: [2024-01-25T14:35:27.341Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] info: [twx-studio:ESPublishClient:Banan] Starting Upload
[2024-01-25T14:35:27.403Z] info: [2024-01-25T14:35:27.400Z][6c6ee85d-4b9e-439a-9510-fd1b421ae24a] info: [twx-studio:ESPublishClient:Banan] zip size 2301418 bytes (approximately 2 MB)
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:47:21.240Z] "GET /api/server/authorize HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined a4f6b360-bb90-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:47:21.262Z] "POST /api/server/token HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 5 ms 0 undefined a4f94b70-bb90-11ee-a0c6-25a6b44b12ff
[2024-01-25T14:47:24.665Z] info: [twx-studio:projectHelper] Building ves-ar-extension app: Banan
[2024-01-25T14:47:25.765Z] info: [twx-studio:projectSettings] Notify preview windows: private-room-Banan
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:47:25.767Z] "POST /api/project/resource/save HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 4499 ms 3842 undefined a4fb2030-bb90-11ee-a0c6-25a6b44b12ff
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:47:25.812Z] "GET /api/switch HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined a7b02e10-bb90-11ee-a0c6-25a6b44b12ff
[2024-01-25T14:47:26.154Z] info: [twx-studio:SaasUtils] Saas=false for server http://127.0.0.1:2019
::1 - 84baf9c7-3fac-4d6b-9bc2-ed0a93c98cc1 [2024-01-25T14:47:26.167Z] "POST /api/publish/ HTTP/1.1" 200 15 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 336 ms 8338 undefined 97ca0beb-a0a3-4389-935d-6cc3afc70c1d
[2024-01-25T14:47:26.168Z] info: [2024-01-25T14:47:26.178Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] warn: [twx-studio:ESPublishClient:Banan] Error retrieving ES capability: omtg 404 Not Found
[2024-01-25T14:47:26.203Z] info: [2024-01-25T14:47:26.202Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] info: [twx-studio:ESPublishClient:Banan] Zipping C:\Users\vuforia\Documents\VuforiaStudio\Projects\Banan\dist
[2024-01-25T14:47:26.931Z] info: [2024-01-25T14:47:26.930Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] info: [twx-studio:ESPublishClient:Banan] filter out entry: extensions/js/libthingview_wasm.wasm
[2024-01-25T14:47:28.053Z] info: [2024-01-25T14:47:28.052Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] info: [twx-studio:ESPublishClient:Banan] zip size 2301447 bytes (approximately 2 MB)
[2024-01-25T14:47:28.053Z] info: [2024-01-25T14:47:28.052Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] info: [twx-studio:ESPublishClient:Banan] Starting Upload
[2024-01-25T14:47:28.073Z] info: [2024-01-25T14:47:28.072Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] info: [twx-studio:ESPublishClient:Banan] zip size 2301447 bytes (approximately 2 MB)
[2024-01-25T14:47:28.073Z] error: [2024-01-25T14:47:28.071Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] error: [twx-studio:ESPublishClient:Banan] Response code 403
[2024-01-25T14:47:28.073Z] error: [2024-01-25T14:47:28.071Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] error: [twx-studio:ESPublishClient:Banan] Response statusText Forbidden
[2024-01-25T14:47:28.073Z] error: [2024-01-25T14:47:28.071Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] error: [twx-studio:ESPublishClient:Banan] Response body {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2024-01-25T14:47:28.073Z] error: [2024-01-25T14:47:28.071Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] error: [twx-studio:ESPublishClient:Banan] Response error undefined
[2024-01-25T14:47:28.073Z] error: [2024-01-25T14:47:28.072Z][97ca0beb-a0a3-4389-935d-6cc3afc70c1d] error: [twx-studio:ESPublishClient:Banan] Failed to upload to the Experience Service. undefined
[2024-01-25T14:47:28.072Z] error: [twx-studio:projectHelper] publishTask error for project Banan {"statusCode":403,"message":"{\"message\":\"Insufficient permissions to access resource\",\"errorCode\":403,\"error\":{}}"}
[2024-01-25T14:47:28.073Z] error: [twx-studio:api] Error occured while publishing project Banan {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2024-01-25T15:15:53.171Z] error: error calling socket callback Error: C:\Users\vuforia\Documents\VuforiaStudio\Projects\tesdts\appConfig.json: ENOENT: no such file or directory, open 'C:\Users\vuforia\Documents\VuforiaStudio\Projects\tesdts\appConfig.json'
[2024-01-25T15:15:53.171Z] error: at Object.openSync (node:fs:603:3)
[2024-01-25T15:15:53.171Z] error: at Object.readFileSync (node:fs:471:35)
[2024-01-25T15:15:53.171Z] error: at Object.readFileSync (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\jsonfile\index.js:50:22)
[2024-01-25T15:15:53.171Z] error: at Object.readSync (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\services\projectSettings.js:274:23)
[2024-01-25T15:15:53.171Z] error: at Socket.onRemoveUnnecessaryGuideViewFiles (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\services\resourceService.js:660:36)
[2024-01-25T15:15:53.171Z] error: at Socket. (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\routes\sockets.js:58:16)
[2024-01-25T15:15:53.171Z] error: at Socket. (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\utils\tryCatchWrapper.js:12:16)
[2024-01-25T15:15:53.171Z] error: at Socket.emit (node:events:517:28)
[2024-01-25T15:15:53.171Z] error: at Socket.emit (node:domain:489:12)
[2024-01-25T15:15:53.171Z] error: at Socket.emitUntyped (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\socket.io\dist\typed-events.js:69:22)
[2024-01-25T15:15:53.171Z] error: at C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\socket.io\dist\socket.js:704:39
[2024-01-25T15:15:53.171Z] error: at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
[2024-01-25T15:15:55.000Z] error: error calling socket callback Error: C:\Users\vuforia\Documents\VuforiaStudio\Projects\tesdts\appConfig.json: ENOENT: no such file or directory, open 'C:\Users\vuforia\Documents\VuforiaStudio\Projects\tesdts\appConfig.json'
[2024-01-25T15:15:55.000Z] error: at Object.openSync (node:fs:603:3)
[2024-01-25T15:15:55.000Z] error: at Object.readFileSync (node:fs:471:35)
[2024-01-25T15:15:55.000Z] error: at Object.readFileSync (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\jsonfile\index.js:50:22)
[2024-01-25T15:15:55.000Z] error: at Object.readSync (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\services\projectSettings.js:274:23)
[2024-01-25T15:15:55.000Z] error: at Socket.onRemoveUnnecessaryGuideViewFiles (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\services\resourceService.js:660:36)
[2024-01-25T15:15:55.000Z] error: at Socket. (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\routes\sockets.js:58:16)
[2024-01-25T15:15:55.000Z] error: at Socket. (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\utils\tryCatchWrapper.js:12:16)
[2024-01-25T15:15:55.000Z] error: at Socket.emit (node:events:517:28)
[2024-01-25T15:15:55.000Z] error: at Socket.emit (node:domain:489:12)
[2024-01-25T15:15:55.000Z] error: at Socket.emitUntyped (C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\socket.io\dist\typed-events.js:69:22)
[2024-01-25T15:15:55.000Z] error: at C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules\socket.io\dist\socket.js:704:39
[2024-01-25T15:15:55.000Z] error: at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
[2024-01-25T15:16:52.980Z] info:
[2024-02-07T11:49:48.700Z] info: ==== Studio.exe 9.16.1.0 ====
[2024-02-07T11:49:48.879Z] info: Status Message: Vorbereitung läuft...
[2024-02-07T11:49:48.879Z] info: Starting node.exe "C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\dist\server\index.js" --writableDistDir="C:\Users\vuforia\AppData\Local\VuforiaStudio\dist"
[2024-02-07T11:49:48.879Z] info: 	NODE_PATH: C:\Program Files\WindowsApps\9CAFC431.26312A8ACB347_9.16.1.0_x64__tv5290srnzce0\VuforiaStudio\node_modules
[2024-02-07T11:50:42.690Z] info: [twx-studio:index] Studio Version 9.16.1.0
[2024-02-07T11:50:42.800Z] info: [twx-studio:initializer] Node version: 18.18.2
[2024-02-07T11:50:42.801Z] info: [twx-studio:initializer] studio launched with the following arguments: {"_":[],"writableDistDir":"C:\\Users\\vuforia\\AppData\\Local\\VuforiaStudio\\dist","$0":"dist\\server\\index.js"}
[2024-02-07T11:50:42.801Z] info: [twx-studio:initializer] studio dir: C:\Users\vuforia\Documents\VuforiaStudio , home dir: C:\Users\vuforia\Documents
[2024-02-07T11:50:42.824Z] info: [twx-studio:configSettingService] C:\ProgramData\VuforiaStudio\config-settings.json was not found, using default config-settings
[2024-02-07T11:51:03.797Z] info: [twx-studio:index] Starting HTTP server...
[2024-02-07T11:51:38.196Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 9.16.1.0
[2024-02-07T11:52:00.968Z] info: [twx-studio:index] Studio Ready http://localhost:3000
::1 - no-active-es [2024-02-07T11:52:51.992Z] "GET /api/projectTemplates HTTP/1.1" 304 "http://localhost:3000/home" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 88 ms undefined 6c1f8de0-c5af-11ee-aa64-dfc2406335ff
[2024-02-07T11:52:52.290Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2024-02-07T11:52:53.980Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
::1 - no-active-es [2024-02-07T11:52:55.439Z] "GET /api/switch HTTP/1.1" 401 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 4 ms undefined 6e3a7ea0-c5af-11ee-aa64-dfc2406335ff
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:52:55.442Z] "GET /api/switch HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1 ms undefined 6e3b6900-c5af-11ee-aa64-dfc2406335ff
[2024-02-07T11:53:02.644Z] info: [twx-studio:auth:oauthHandler] Server is not OAuth http://127.0.0.1:2019
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:02.671Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 6314 ms undefined 3a4cebba-ce9f-47b6-b619-184d082d7ed1
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:02.747Z] "GET /api/server/authorize HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 3 ms undefined 7295c270-c5af-11ee-aa64-dfc2406335ff
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:02.769Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 6 ms undefined d21928dd-d8a6-41e2-a08e-9a28b38c957c
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:02.816Z] "GET /ExperienceService/.well-known/is-saas HTTP/1.1" 404 49 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 7 ms undefined ff5b2252-2ea4-48d4-b2cb-c064d7df66ce
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:03.089Z] "POST /api/server/token HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 239 ms 0 undefined 72a5c800-c5af-11ee-aa64-dfc2406335ff
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:03.163Z] "GET /ExperienceService/viewCommandHost HTTP/1.1" 200 24 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 61 ms undefined 1f17abc1-9906-4856-a2ab-55754d5b7b4f
[2024-02-07T11:53:17.560Z] info: [twx-studio:projectHelper] Building ves-ar-extension app: Banan
[2024-02-07T11:53:49.709Z] info: [twx-studio:projectSettings] Notify preview windows: private-room-Banan
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:49.711Z] "POST /api/project/resource/save HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 46600 ms 1066 undefined 72cdc260-c5af-11ee-aa64-dfc2406335ff
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:49.780Z] "GET /api/switch HTTP/1.1" 200 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 5 ms undefined 8e9e1ee0-c5af-11ee-aa64-dfc2406335ff
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:53:49.846Z] "POST /api/publish/ HTTP/1.1" 401 37 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 56 ms 5977 undefined fedb72b2-bddc-4540-98e8-31eef06def08
[2024-02-07T11:54:06.210Z] info: [twx-studio:SaasUtils] Saas=false for server http://127.0.0.1:2019
::1 - ff42ffe4-67d9-4503-9127-0cd63b6f3acd [2024-02-07T11:54:06.223Z] "POST /api/publish/ HTTP/1.1" 200 15 "http://localhost:3000/design/Banan" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0" 1168 ms 5977 undefined fedb72b2-bddc-4540-98e8-31eef06def08
[2024-02-07T11:54:06.224Z] info: [2024-02-07T11:54:06.226Z][fedb72b2-bddc-4540-98e8-31eef06def08] warn: [twx-studio:ESPublishClient:Banan] Error retrieving ES capability: omtg 404 Not Found
[2024-02-07T11:54:06.270Z] info: [2024-02-07T11:54:06.269Z][fedb72b2-bddc-4540-98e8-31eef06def08] info: [twx-studio:ESPublishClient:Banan] Zipping C:\Users\vuforia\Documents\VuforiaStudio\Projects\Banan\dist
[2024-02-07T11:54:07.094Z] info: [2024-02-07T11:54:07.093Z][fedb72b2-bddc-4540-98e8-31eef06def08] info: [twx-studio:ESPublishClient:Banan] filter out entry: extensions/js/libthingview_wasm.wasm
[2024-02-07T11:54:08.643Z] info: [2024-02-07T11:54:08.643Z][fedb72b2-bddc-4540-98e8-31eef06def08] info: [twx-studio:ESPublishClient:Banan] zip size 2301502 bytes (approximately 2 MB)
[2024-02-07T11:54:08.643Z] info: [2024-02-07T11:54:08.643Z][fedb72b2-bddc-4540-98e8-31eef06def08] info: [twx-studio:ESPublishClient:Banan] Starting Upload
[2024-02-07T11:54:08.762Z] info: [2024-02-07T11:54:08.762Z][fedb72b2-bddc-4540-98e8-31eef06def08] info: [twx-studio:ESPublishClient:Banan] zip size 2301502 bytes (approximately 2 MB)
[2024-02-07T11:54:08.762Z] error: [2024-02-07T11:54:08.761Z][fedb72b2-bddc-4540-98e8-31eef06def08] error: [twx-studio:ESPublishClient:Banan] Response code 403
[2024-02-07T11:54:08.762Z] error: [2024-02-07T11:54:08.761Z][fedb72b2-bddc-4540-98e8-31eef06def08] error: [twx-studio:ESPublishClient:Banan] Response statusText Forbidden
[2024-02-07T11:54:08.762Z] error: [2024-02-07T11:54:08.762Z][fedb72b2-bddc-4540-98e8-31eef06def08] error: [twx-studio:ESPublishClient:Banan] Response body {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2024-02-07T11:54:08.762Z] error: [2024-02-07T11:54:08.762Z][fedb72b2-bddc-4540-98e8-31eef06def08] error: [twx-studio:ESPublishClient:Banan] Response error undefined
[2024-02-07T11:54:08.762Z] error: [2024-02-07T11:54:08.762Z][fedb72b2-bddc-4540-98e8-31eef06def08] error: [twx-studio:ESPublishClient:Banan] Failed to upload to the Experience Service. undefined
[2024-02-07T11:54:08.762Z] error: [twx-studio:projectHelper] publishTask error for project Banan {"statusCode":403,"message":"{\"message\":\"Insufficient permissions to access resource\",\"errorCode\":403,\"error\":{}}"}
[2024-02-07T11:54:08.762Z] error: [twx-studio:api] Error occured while publishing project Banan {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
This Error also get triggered if I do not try to uplode a projectr lokal. I also tryed this from other devices. Same Error.
I reinstalled the Services several times now.
Best wishes.
