Jun 23, 2023 7:43 AM UTC
How can I get the coordinates of a selected part in "Vuforia Studio"?
I tried the following, but could not get the correct coordinates.
tml3dRenderer.GetObject('model-1-/3').GetWidget().GetLocation().position.x
 Specifically, no matter which part was selected, all X, Y, and Z coordinates were always zero.
nishihiraAnswer
Jun 26, 2023 2:12 AM UTC
Thank you. I guess I'll have to create a dedicated metadata. I'll do my best to create a metadata with coordinates.
Jun 23, 2023 8:47 AM UTC
Hi @nishihira ,
so far I know the GetWidget() method will not work on some/or all mobile platforms - so seem that is  only reported in chrome - and possibly  this indented for UI usage. Therefore I thing this work in chrome browser only. Here I could find a old test code where I tested this feature in js.
$scope.testButton=()=>{console.warn($scope);console.warn(tml3dRenderer);
 $scope.setWidgetProp('modelItem-1','rx',45.0);
 $scope.setWidgetProp('modelItem-2','rx',45.0);
if( isPreview()) {
 //modelItem-1
 console.warn( tml3dRenderer.GetObject('model-1-/0/0/10/2').GetWidget().GetLocation() );
 console.info("X="+ tml3dRenderer.GetObject('model-1-/0/0/10/2').GetWidget().GetLocation().position.x );
 //modelItem-2
 console.warn( tml3dRenderer.GetObject('model-1-/0/0/10/1').GetWidget().GetLocation() );
 console.info("X="+ tml3dRenderer.GetObject('model-1-/0/0/10/1').GetWidget().GetLocation().position.x );
 $scope.$applyAsync();
//where the preview check is defined as
isPreview = function() {
 if(window.twx.app.isPreview()) // is in Preview
 return true;
 return false; }
So what possibly you can use instead is some techniques as described in the boding box - so getting information via metadata which is extracted as in the following link is mentioned.
https://community.ptc.com/t5/Vuforia-Studio/Obtaining-Bounding-Boxes-for-3D-Models/m-p/779434#M10634
https://community.ptc.com/t5/Vuforia-Studio/metadata-vuforia-experience-service/m-p/778822#M10621
https://community.ptc.com/t5/Vuforia-Studio/metadata-vuforia-experience-service/m-p/779433#M10633
Jun 23, 2023 9:02 AM UTC
So when extracted and imported the metadata in Studio via the CreoViewRWExtension
$scope.app.getAttrArr= function(modelName,pathId,attribute) {
 let retVal= [0.,0.,0.,0.,0.,0.];
try {
let arr= metaDataArray[modelName].data[pathId]['__PV_SystemProperties'][attribute].split(' ');
 for (let i=0;i<6;i++) retVal[i]= parseFloat(arr[i]);
 return retVal;
catch(e) {return retVal;}
$scope.app.getModTransformMat= function(modelName,pathId) {
return $scope.app.getAttrMat(modelName,pathId,'Model Transformation'); }
$scope.app.getInstTransformMat= function(modelName,pathId) {
return $scope.app.getAttrMat(modelName,pathId,'Instance Transformation'); }
$scope.app.getModLocationMat= function(modelName,pathId) {
return $scope.eulerVec2trfMatR ($scope.app.getAttrArr(modelName,pathId,'Model Location'));
$scope.app.getInstLocationMat= function(modelName,pathId) {
return $scope.eulerVec2trfMatR ($scope.app.getAttrArr(modelName,pathId,'Instance Location'));
 I used some functions as mentioned in  this sample studio project where tried to apply more complex operations like space rotation via any csys point - where all calculation are based on  the meta data which was extracted via the  CreoViewRWExtension.
So possibly could be helpful as additional information
nishihira10-MarbleAuthor
Jun 23, 2023 10:15 AM UTC
Thank you @RolandRaytchev for your speedy and thorough replies! However, as you said, it didn't work on mobile platforms.Thanks also for the suggestion to get it from the metadata. Unfortunately, however, there is no coordinate information in the metadata of the CAD data we are dealing with.
