Sep 27, 2020 7:15 AM UTC
How to make the readings of a 3D Gauge decrease and stop at a particular value.
I want to make the readings of a 3D Gauge decrease and stop at a certain value once a function has been triggered. Once the 3D gauge reading stops at that particular value, I want to change the resource image of the 3D Gauge to indicate an alert / caution.
sdidierAnswer
Sep 28, 2020 8:39 AM UTC
Hello ES_9419715,
Sadly here, Enable State-Based Formatting will not help because image is not part of the properties manageable like that.
The behavior wanted seems like an animation.
So Javascript functions will need to use a timeout to let the end user to see the effect.
Please have a look to this thread about timeout function :
https://community.ptc.com/t5/Vuforia-Studio/How-do-I-add-a-simple-10-second-delay-after-a-button-is-pressed/m-p/513176#M2118
https://docs.angularjs.org/api/ng/service/$timeout
To change a resource of any 3D or 2D Widget, please have a look to this thread :
https://community.ptc.com/t5/Vuforia-Studio/How-to-change-resource-of-3D-image-with-JS-code/m-p/612438
So, source code who be similar to like that :
$scope.ChangeIcon = function()
 console.log ("ChangeIcon");
 //$scope.setWidgetProp('3DGaugeExample', 'resource', "app/resources/Uploaded/Fichier_Stop_hand.svg");
 $scope.view.wdg["3DGaugeExample"]['resource'] = 'app/resources/Uploaded/Fichier_Stop_hand.svg';
$scope.CheckChangeIcon = function(val)
 // Low limit of value displayed in 3D Gauge
 if (val <= 1)
 // Change image of this 3D Gauge in 5 ms
	$timeout($scope.ChangeIcon, 5);
$scope.DecreaseValue = function()
 // Read current value of 3D Gauge. Start value is at 20.
 var value = $scope.getWidgetProp('3DGaugeExample', 'text');
 $scope.CheckChangeIcon (value);
 if (value == 1)
 return;
 // Decrease value
 value = value - 1;
 // Apply the value
 $scope.setWidgetProp('3DGaugeExample', 'text', value);
 if (value > 1)
 // Continue to decrease
 $timeout($scope.DecreaseValue, 1);
$scope.Start = function()
 // Decrease value of 1 in 1 ms later
Please find a sample Project.
It has one issue where I am blocking.
Image is not applied in 3D Gauge but Function is called as expected.
Some investigation is needed about this point.
Best regards,
Samuel
sdidier17-PeridotAnswer
Hello ES_9419715,
 if (val <= 1)
 if (value == 1)
 return;
 // Decrease value
 value = value - 1;
 // Apply the value
 if (value > 1)
Best regards,
Samuel
Sep 28, 2020 12:22 PM UTC
Hello @sdidier ,
nice project example. One thing we need to change there. The resource properie from UI is "src" in JavaScript so therefore we need to change the statement:
// please change it to
$scope.view.wdg["3DGaugeExample"]['src'] = 'app/resources/Uploaded/Fichier_Stop_hand.svg';
