8-Gravel
Feb 8, 2023 10:52 AM UTC
Model rotation - please share sample project
I have an urgent requirement of the same!
Can you please share any sample project which defines the second method you mentioned in this post i.e "User Euler calculate to transform the axis. In this case you will have a set of values  x,y,z, rx ,ry,  rz – combination of space shift and rotation which will result the desired rotation."
Thank you in advance!
RE: post
Feb 8, 2023 2:28 PM UTC
Hi @Dhaval_Bendale ,
here I want to provide an example showing how to rotate a first level component according to any spatial axis. I never get working for deeper level component, no I idea why this did not work. I think I did post this example in the past# to this post https://community.ptc.com/t5/Vuforia-Studio/Possibility-to-change-set-the-spincenter-csys-of-models-and/m-p/796282#M10843
Here the link to download the project
For this I needed 2 things 1.) to extract the location matrix of the assembly (via extension , please check the post  for more details. Please, let me know if you have questions.
