Jul 18, 2019 7:15 PM UTC
Model Target with Hololensv1
Hi ,
In Vuforia studio when I am using Model Target for Holoens, Tracking and size are correct as per real Hardware, but as my view changes the 3d Model is not stationary, similar like using on Image target.
Is there any way to get Stationary properties for Model Target?
Jul 19, 2019 2:01 PM UTC
Hi @Parimal_Sahu,
so far, I know it is possible to set stationary property on the model target.
So, for that what could make is more stable I want to refer to the post
Whit java script we could set the following 3D Container widget properties additional to the GUI
$rootScope.$on('modelLoaded', function() {
 $scope.check_if_works=false
 $scope.setWidgetProp('3DContainer-1','enabletrackingevents',true);
 $scope.setWidgetProp('3DContainer-1','dropshadow',true);
 $scope.setWidgetProp('3DContainer-1','extendedtracking',true);
 $scope.setWidgetProp('3DContainer-1','persistmap',true);
So maybe the extendedtracking and persistmap properties could have some positive effect in your case
Jul 23, 2019 9:40 AM UTC
Thanks Roland for reply,
I was looking solution for Hololens and  3d container of 3d Eyewear has very limited properties available.
so even I have your code the result did not improved because it does not have extendedTracking, enableTrackingevents
Jul 23, 2019 11:04 AM UTC
Yes , correct !  I am sorry, it was mistake in my post - the first sentence should mean „ so far I know, it is NOT possible to set stationary property on model target" –
I just wanted to mention the properties  we can set with javascript with the hope that it could have some positive effect in your case .
