Dec 5, 2019 6:39 AM UTC
Navigate between Views using CSS
Hello all,
Is there any possibility to navigate between different views using CSS.
Thanks in Advance.
VR
18-Opal
Dec 11, 2019 2:29 PM UTC
Something like this should work:
window.addEventListener("orientationchange", function() {
 alert("rotate!");
 var width = window.innerWidth;
 var height = window.innerHeight;
 // assume your two views are named "Portrait" and "Landscape"
 if(width > height) {
 $scope.app.fn.navigate("Landscape");
 else {
 $scope.app.fn.navigate("Portrait");
Note that you'll only want to add this once, in your initial view, since it attaches to the top level window object, and it will trigger no matter which view is active. You don't need separate copies in each view.js panel.
18-Opal
Dec 6, 2019 2:58 PM UTC
I don't see how that would work with CSS, but you can certainly do it with Javascript. You can also do it using a UI widget (like a button) with a binding to the navigate service on the view.
Velkumar19-TanzaniteAuthor
Dec 11, 2019 4:05 AM UTC
Hello @ClayHelberg
Thanks for your reply. My use case to switch between views based on Orientation of the device. I tried using using javascript to find orientation of the device, but it doesn't work. So I'm looking in CSS to achieve this.
/VR
Dec 11, 2019 12:19 PM UTC
Hello Velkumar
maybe this will help you for detect an orientation:
$scope.getOrientation = function() {
 console.info("display size: " + width + "x" + height);
 var orientation = "";
 orientation = "landscape";
 else {
 orientation = "portrait";
 console.info(orientation);
 return orientation;
Regards
Tomas
Dec 11, 2019 9:09 AM UTC
its not possible with CSS. its possible with binding of button or toggle button with navigate property
