Dec 2, 2024 4:22 AM UTC
PDF Viewer Extension not working
I am using Vuforia Studio 9.22.
The PDF Viewer Extension no longer launches.
I preview using Windo
I check the output experience on my iPad.
I would like to display it in PDF without converting it to SVG.
Translated the topic from Japanese to English using google translate
Subject - PDF Viewer Extensionが機能しない
Body - Vuforia Studio 9.22を使用しています。
PDF Viewer Extensionが起動しなくなりました。
プレビューはWind
出力したエクスペリエンスはIpadで確認しています。
SVGに変換せずにPDFで表示させたいです。
-By Community Moderation Team
PEHOWEAnswer
Jan 2, 2025 6:00 PM UTC
Hello @ADS_116 ,
I located a version 0.7 which should work in Studio 9.2.2.
Let me know if this works. The ZIP file is not as nicely structured as previous versions so please let me know if you have any questions.
Pehowe
Dec 2, 2024 8:13 AM UTC
Same issue - "PDF Viewer Extension not working": https://community.ptc.com/t5/Vuforia-Studio/PDF-Viewer-Extension-not-working/td-p/918967
ADS_1164-ParticipantAuthor
Dec 3, 2024 12:12 AM UTC
I checked this community and tried it, but it didn't solve the problem.
I wish there was a newer version of PDF Viewer...
Translated the below content from Japanese to English using google translate
こちらのコミュニティは確認し、試してみましたが問題は解決しませんでした。
PDF Viewerの最新バージョンがあればいいのですが・・・
- By Community Moderation Team
Jan 2, 2025 5:54 PM UTC
Hello @真泉_10739920 ,
I looked at the issue you described. It appears the version listed in the article is now working with the Vuforia Studio version you are using.
Let me see what I can locate.
Pehowe
PEHOWE17-PeridotAnswer
Hello @ADS_116 ,
Pehowe
Feb 14, 2025 4:46 AM UTC
こちらのPDF Viewerのバージョンを入れたところ、無事動作しました。
ご提供ありがとうございました。大変助かりました。
ちなみにソース元がどこか教えてもらうことはできますか?
Feb 17, 2025 3:33 PM UTC
@ADS_116
I located the update on https://github.com/sbruegel/StudioPDFViewer
Hope that helps
Pehowe
