Mar 29, 2019 3:06 PM UTC
Re: Problems with playing sequences on HoloLens
<this is a new post based on a  quesiton to the old topic >
sequences are now working quite better.
Does anyone have a clue how to play 2 or more sequences on hololens?
Bojan
    Mar 29, 2019 5:18 PM UTC
    Hi @bgračnar
    yes this is possible via javaScript. Example for playing of 2 sequneces
     $scope.app.sequence1 = function() {
     console.log("called $scope.sequence1");
     $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_1.pvi';
     $timeout(
     //function() {angular.element(document.getElementById('model-1')).scope().playAll();}
     function() { $scope.$broadcast('app.view["Home"].wdg["model-1"].svc.playAll');
     $scope.$applyAsync();
     },1000);
     console.log("finished $scope.sequence1");
    $scope.app.sequence2 = function() {
     console.log("called $scope.sequence2");
     $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_2.pvi';
     //$timeout(function() {angular.element(document.getElementById('model-1')).scope().playAll();},1000);
     $timeout(
     },1000);
     console.log("finished $scope.sequence2");
    $scope.app.sequence = function() {
     $scope.app.sequence1();
     $scope.app.sequence2();
    Ok the code above could work ok but there is another version which is more stable when you try  to play a sequence  on start / after model loaded event.
    Here is another example which is more robust . There are  2 different functions for the calling of  play respectively  playAll .
    $scope.app.loadsequence = function()
    	{ $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - TestFigure1.pvi");
    	 twx.app.fn.triggerWidgetService("model-1", 'play');
     $rootScope.$on('modelLoaded', function()
     {$scope.app.loadsequence();
     console.warn("$scope.app.loadsequence() executed");
     				$timeout( function() {
     console.warn("app.loadsequence() executed");
     }, 1000);
    $scope.app.loadsequence1 = function()
    	{ $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - SecondTestFigure.pvi");
    	 twx.app.fn.triggerWidgetService("model-1", 'playAll');
    I think it is possible to execute more than one sequence consecutively  in particular order. I could not remember if this was working but if there is a problem we can try to call the next sequence from the step-completed event of the last step (ok this requires some additional checks) but we need to consider this only if we face a problem when calling several sequences consecutively
    bgračnar10-MarbleAuthor
    Apr 1, 2019 12:46 PM UTC
    Roland,
    thank you wery much for answer!
    I see that there is option to play one sequence after another.
    I guess there is no option to selecting sequences (for service procedures)?
    Bojan
