3-Newcomer
Jul 28, 2026 11:00 AM UTC
Recommended approach for AR tracking of split AC indoor units — low-texture, near-symmetric, near-identical SKU variants
What we are building
AR service and self-help features inside an existing consumer mobile app for a
major air conditioner manufacturer. We are evaluating Vuforia Engine and would
like your recommendation on the right approach before we commit to a design.
The objects
Wall-mounted split AC indoor units.
- Elongated rectangular body, approx. 800-1100 x 300 x 200 mm
- Glossy white plastic fascia, very low surface texture
- Low geometric complexity, few sharp edges or distinguishing features
- Near-symmetric about the vertical axis
- Multiple SKUs across the range are near-identical in external appearance
- Hinged front intake flap (moving part)
- A rating plate with model number and barcode is present on every unit
Usage conditions
- Mounted 2.5-3 m above floor; users view upward from 1.5-3 m away
- Typical indoor residential lighting, often uneven or backlit
- Two user types: consumers (standing in the room) and service technicians
  (close range, on a ladder, unit panel opened)
Constraints
- Native SDK integration into existing Android (Kotlin) and iOS (Swift) apps,
  not Unity
- Minimum Android 10 / iOS 14, mid-range consumer devices
- Must work on units already installed in customers' homes, so we cannot rely
  on markers being applied at manufacture
- CAD models are available from the manufacturer
- Deployment would be on a Premium plan
What we would like from you
1. Which Vuforia features would you recommend for this object class, and would
   you consider these units suitable targets at all?
2. How would you approach distinguishing SKUs that look near-identical?
3. Where would you expect this approach to fail, and what would you recommend
   as a fallback?
Catalina
Community Manager
Aug 7, 2026 12:01 PM UTC
Hi ​@MP_14638635
Thank you for your question. 
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Catalina | PTC Community Manager
