Apr 26, 2022 1:10 PM UTC
Section animation from illustrate
Hello, I've prepared a section animation step in a sequence from creo illustrate.
when importing the pvz into vuforia studio the sectioning animation is not shown.
Why? How to solve this issue?
Thank you
Apr 29, 2022 4:11 PM UTC
Currently sectioning sequence is not supported
May 2, 2022 5:40 AM UTC
You could achieve this functionality using js. Have a look at solution 3.) at this post:
Section view or Clipping of model display in Vu... - PTC Community
Instead of a slider you can use a loop that lets the variable slicexCur add up.
