Jan 16, 2017 3:24 PM UTC
Unpublishing Experiences from Server
In the event the actual project files were deleted from the documents folder, and the machine that published the experience was reset, is there a way to manage all published experiences on a server and delete them in the event that needs to be done?
katteAnswer
Jan 16, 2017 3:38 PM UTC
By saying manage, do you mean deleting the experience projects? If that is the case, you can leverage REST call using Postman and use Delete method as follows:
** If you are registered for the initial Pilot Program, then replace "/ExperienceService" with "/VuforiaExperienceService" in the URL.
Giri
katte5-Regular MemberAnswer
Giri
Jan 25, 2017 3:08 AM UTC
Hi Giri,
I've followed your instructions and managed to delete a bunch of published experiences that I didn't want.  However, for some of them, I no longer have the local project folder and I don't know what it was named.  So how can I get rid of these if I don't know the project name.  I do know the name of the Experience, as I see that listed when I scan the ThingMark.
Many thanks,
Allan
Jan 25, 2017 2:43 PM UTC
Allan, To know the list of project names, likewise 'DELETE' method you can make use of 'GET' method in postman. The url should look like - https://<yourhostname>:<port>/ExperienceService/content/projects/
Alternately, you can use CURL command as: curl -u user:password -H Accept:application/json https://<yourhostname>:<port>/ExperienceService/content/projects/
-Giri
Jul 20, 2018 1:49 AM UTC
I have a easy way to delete experience server file.
Create a same name project then publish. You can delete cloud file.
