9.0 Apache on Windows Server 2008 R1
Hello.
Has anyone gotten 9.0 M030 to install on a Windows Server 2008 R1? I now it is not certified but wondering if anyone has done it?
Have a 9.0 M030 Installation that can NOT beupdated... User Profile and Installer/Inst Reg Folders were deleted so no ability to Update... PTC Tech Support attempting to build one from scratch but have been slow to respond on any progress since they took the files last night.
We have a Windows 2008 Server R1 available. Thought I would Classically Rehost. (IE Install a New 9.0 M030 Installation)
But PTC Solution INstaller for 9.0 (With Apache Fails)
"Installation is Aborting
The following logs contain information that may help you....."
You can install 8.0 on Windows 2008 Server (Its been done for updates from 8.0 to 9.1)...
.... can not update and then Rehost (Do to missing files) and can not rehost then update (Since 9.0 M030 will not install on uncertified Windows 2008 Server R1. (Though 9.1 Apache does... PTC Solution INstaller would not recognize for PDMLink install)
Anyone gotten 9.0 Apache to run? Or Built a psi_iir_index.xml from scratch?
1. Account Management Off
2. No Virus Software
3. Firewall Disabled
Brian
Brian
