9.1 - 10.2 Upgrade: Type data loader for 10.0 fails
  • January 31, 2014
  • 4 replies
  • 1211 views
Any successful 9.1-10.2 upgrades out there?
While running the UpgradeManager, the Load New Data task fails at the Type data loader for 10.0 step.
I can find nothing that addresses this specific error.
Caused by: wt.util.WTException: (wt.ixb.publicforhandlers.ixbResource/8) wt.ixb.publicforhandlers.LogHelper$IxbException: Problem in export/import process.
Nested exception is: (wt.ixb.handlers.netmarkets.NMIxResources/108) wt.util.WTException: Loader method com.ptc.core.lwc.server.TypeDefinitionLoader.endProcessTypeDefinition reported a failure
Has anyone had and solved this issue?
joe bell
GSIMS Administrator
GPS Sustainment Information Management System
719-572-2890
bellj@gpssims.com<">mailto:bellj@gpssims.com>
Hi Joseph can you provide more information? The UpgradeManager reports perhaps?
[Description: C:\Documents and Settings\krista.roy\Application Data\Microsoft\Signatures\tristar_email_signature_files\image001.gif]
Steve Vinyard
Senior Solution Architect
I'm with Steve,
What is your Windchill configuration. (i.e.winchill version.) Was your schema properly updateded? Do you have Partslink also installed with a different database user?
Is the log specifically from the upgrademanager.log/xml?
Was there any successful load of data before this step. Can you repeat it? Rehost from production then reupgrade again.
Patrick
In Reply to joe bell:
joe bell
GSIMS Administrator
719-572-2890
bellj@gpssims.com<
bellj1-VisitorAuthor
I am installing 10.2 M010 which doesn't have any patches but you're right about the db version needing to be 11.2.0.2.
I am at 11.2.0.1.
I thought I had the latest version but I guess not.
Thanks!
joe bell
GSIMS Administrator
719-572-2890
Thank You.
I'm going to download it now.
I switched my install from 10.1 to 10.2 when it came out and didn't check the software compatibility matrix.
joe bell
GSIMS Administrator
719-572-2890
