9.1 M060 on Windows Server 2008 R2 Login Problem
  • October 19, 2010
  • 4 replies
  • 904 views
I have a fresh OOTB installation of WC 9.1 M060 on a Windows Server 2008 R2 machine. I have configured Apache, Tomcat, Windchill, and WindchillDS as Windows services. I am unable to login to WC from a client machine. However, I can successfully login when I am on the server itself. When on the client I can browse to the Tomcat and Info*Engine validation page (http://<servername>/Windchill/infoengine/jsp/examples/VerifyIE.jsp) and I get prompted for a user/pass and all validation works fine. Additionally I can browse to the test.html (http://<servername>/Windchill/wtcore/test.html) and all "Authenticated" links work fine. Only when I try and browse to WC itself I am not prompted to authenticate and I get a page that says "There is a problem with this web page...bla bla bla". I do see the PTC logo but that's it. Am I missing something in the Apache configuration such as a resource in the app-Windchill-AuthRes.xml file? Oh, virus scanning and firewall are turned off as well and no errors show up in the Apache or Tomcat logs.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995(business)
+1 520.545.6399(fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
avillanueva
23-Emerald I
October 19, 2010
Additional test. From Windchill command prompt, try:
windchill wt.auth.Authentication
Should prompt for login.
Tried putting tomcat and apache into debug mode?
Sent from my Verizon Wireless BlackBerry
Sorry about that last email, I see it is now supported. Do you have UAC turned off? We had a lot of issue with that blocking Apache and Tomcat when we started with Server 2008.
Tyler
That works too.
Additionally, R2 is supported. Check the matrices.
I think the problem is that what the PSI picked up for the DNS name isn't
what really is in the DNS. It missed part of the domain name.
PATRICK S WILLIAMS
Information Technology
Mechanical Engr Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (office)
+1 520.446.0244 (pager)
+1 520.545.6399 (fax)
Tucson, AZ 85706-5093 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
