A couple of migration questions.
I'm in the metadata-only phase of migrating three 3.4 databases to a single 9.1 M040 install.
In the ildataloader AsStored phase, I see several messages like this:
INFO loadercontroller.AsStoredConfigController - For an AsStored with txnid:15676, a member with pivid: 747857 was migrated as secondary content and hence, is no longer a member of the migrated AsStored
I don't know what the txnid and pivid numbers are referring to. What, if anything, do I need to do with this information? How can I tell what type of object it refers to?
My second question refers to the instructions to run the EPM Family Table validation in WinDU. I've run it and the log file shows several messages similar to the following:
ERROR|wt.epm.familytable.EPMParameterValue|1685004|20270
Again, I don't know what these numbers mean or what to do about them. The last number seems to be a constant - it appears on every message in all databases.
Does anyone know what this stuff means? Thanks in advance.
