Administrators unable to create instantiable Document sub-type even with proper Access Control defined (Windchill PDMLink 10.0 M040)
  • August 19, 2014
  • 2 replies
  • 1625 views
Any user, even Administrators, with Create access to a WTDocument sub-type is unable to see the sub-type in the Document Creation Wizard drop-down list. (Windchill PDMLink 10.0 M040)
Best answer by MikeLockwood
If you have an OIR for this sub type, does the OIR specify a lifecycle template that doesn't exist- maybe a typo in the name? Can disable the OIR for the type temporarily, which will cause the type to use the parent (WTDoc) OIR - see if appears then.
Maybe try New Document at Site level Folders, eliminating anything going on at a lower context.
22-Sapphire I
August 19, 2014
sray1-VisitorAuthor
The lifecycle template mentioned in the OIR was not enabled. We detected this after disabling the OIR (so that it could successfully fall back on the WTDocument OIR)
