avillanueva
23-Emerald I
January 13, 2010
Anyone worked with custom Queues?
  • January 13, 2010
  • 2 replies
  • 1297 views
Just looking for tips and pitfalls to avoid. I am considering adding
another listener to the system to listen on various events of a subset
of parts (soft-types). If any action is to be taken, it does not have to
be processed right away and I want to avoid the listener blocking the
primary event from continuing. Basically, I have an outside database of
parts records I want to keep in sync with parts in PDMLink.
I am thinking of creating my own processing queue and have the listener
add entries (ProcessingQueue.addEntry(...)) to the queue. I can then
use the same process to do periodic syncs of the records (queue up all
the qualifying part records). API looks pretty straight forward. Am I
correct in assuming the following:
addEntry takes the following:
public QueueEntry
<file: c:\ptc\windchill_9.1\windchill\codebase\wt\clients\library\api\<br="/>wt\queue\QueueEntry.html> addEntry(WTPrincipal
<file: c:\ptc\windchill_9.1\windchill\codebase\wt\clients\library\api\<br="/>wt\org\WTPrincipal.html> princ,
String
<">http://java.sun.com/j2se/1.5.0/docs/api/java/lang/String.html>
t_method,
String
t_class,
Class
<">http://java.sun.com/j2se/1.5.0/docs/api/java/lang/Class.html> []
arg_types,
Object
<">http://java.sun.com/j2se/1.5.0/docs/api/java/lang/Object.html> [] args)
throws WTException
<file: c:\ptc\windchill_9.1\windchill\codebase\wt\clients\library\api\<br="/>wt\util\WTException.html>
The processing queue executes the QueueEntry which calls the class and
method above passing in the arguments and argument class types above.
This uses reflection, no?
Tony,
Yes, we created schedule and process queues to import, export, XML data, and
conduct mass changes to Bills of Materials.
Can be accomplished either by info engine task or a custom java program.
Please visit our Mass Change Solution that conducts mass changes using queue
based processing.
hjatla@datafrond.com | Fax: +1 480.247.5908
:DF_logo.tif
avillanueva
23-Emerald I
January 13, 2010
"good notification mechanism" - other than emails based on the queue
manager? I intend to have copious logging, where I can actually track a
queue entry back to what the heck its related to.
