Asynchronous jlink and dialog box
  • July 17, 2012
  • 3 replies
  • 939 views
I am currently developping a JLink application that will work on an
asynchronous basis, using the options no_graphics.
But sometimes some message box pops in the PROE session causing the
asynchronous program to be unable to get back control (PROE awaits for an
answer to the message box).
Is there any way to deal with it ? Always answering "YES" for instance ? If
so, how it has to be implemented ?
Thibault Magné
Thanks you for the answer. Unfortunately, I already have set this option as
it is indicated in the jlink user's guide. But message box still appears.
The PROE used is Creo 5 M120.
Thibault Magné
2012/7/17 Williams, Patrick <->
> Add "-i:rpc_input" to your "-g:no_graphics" option and all dialog boxes
> will be suppressed.****
> *Patrick Williams* | Engineering Systems | o: 616.698.3766 | c:
> 616.947.2110****
> [image: sc_inc_black_sig_1_alt]****
> *From:* Thibault Magné [
> If so, how it has to be implemented ?****
> Regards,****
> Thibault Magné****
Then you need to file a ticket with PTC as a bug.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CD63FA.7A901850]
That's what I was thinking but needed a confirmation.
Thanks you very much,
Thibault Magné
> Then you need to file a ticket with PTC as a bug.****
> 616.947.2110****
> *From:* Thibault Magné [mailto:-]
> *Sent:* Tuesday, July 17, 2012 8:56 AM
> *To:* Williams, Patrick; -
> *Subject:* Re: [solutions] - Asynchronous jlink and dialog box****
> Hi,****
> as it is indicated in the jlink user's guide. But message box still appears.
> The PROE used is Creo 5 M120.****
> Regards,****
> Thibault Magné****
> 2012/7/17 Williams, Patrick <->****
> Add “-i:rpc_input” to your “-g:no_graphics” option and all dialog boxes
> 616.947.2110****
> *Sent:* Tuesday, July 17, 2012 8:38 AM
> *To:* -
> *Subject:* [solutions] - Asynchronous jlink and dialog box
> Hi,****
> asynchronous basis, using the options no_graphics.****
> answer to the message box).****
> Regards,****
> Thibault Magné****
