Attributes - Create through loader
  • April 3, 2024
  • 5 replies
  • 1171 views
Hi Guys,
Can we use the loader to create an attribute name that we can add to the selected WT part?
AJ
HelesicPetr
Hi @Amirtharaj_K
Check following article that describes how to export and import the attribute definition in the system.
You can export and check how the XML input files are structured and you can create own to load the attributes
CS30168 - How to export and import soft types and attributes using 'LoadFromFile' in Windchill
PetrH
Thanks for the reply @HelesicPetr
Article - CS59960 i refer this to create an attributes.
How can we add attributes to a specific type of WT Part, EPM Document, ECN, and other types?
Aj
HelesicPetr
Hi @Amirtharaj_K
You have to study the exported xml content and find a logic how it works.
Then you would be able to crate new one definition with the soft attributes.
PetrH
