Attributes - Discrete set values using Resource Bundle?
I just put in this tech support call:
We are using the attribute "Project Charge Number" assigned to multiple types with the Discrete Set constraint. Users select a number and all work done is charged to it. This is for accounting purposes for hours worked by various groups / departments. We currently use the same set of charge numbers for two different types of Change Request and also two types of work request (we're using a sub type of Change Request as Work Request). The valid list of Project Charge Numbers updates frequently. We have to independently update the list for each type. Question: Is there some way to have a single list applied? It appears that the ideal solution would be to use a resource bundle, and to have the values displayed in a Discrete Set be the current values of the Resource Bundle. Is this possible? Has anyone done this? Any other suggestions?
