7-Bedrock
Mar 20, 2026 2:00 PM UTC
Authentication Priority Issue After Upgrading from Windchill 12.1.2.4 to 13.1.2.0 (OpenDJ Preferred
Version: Windchill 13.1
Use Case: I am experiencing an authentication priority issue after upgrading Windchill from 12.1.2.4 to 13.1.2.0, and I would appreciate advice from anyone who has faced and resolved a similar situation.
Description:
■ Previous Environment (12.1.2.4)
  • User information stored in WindchillDS
  • Password authentication performed via JNDI adapter, using Active Directory
■ Current Environment (13.1.2.0)
  • Replaced WindchillDS with OpenDJ
  • Intended configuration is the same as before:
    • User information in OpenDJ
    • Password authentication by Active Directory via JNDI adapter
■ Problem
With the same configuration applied in 13.1.2.0, OpenDJ is being used for authentication first, instead of Active Directory.
However:
  • The properties
    • mapcredentials.admin.adapters
    • wt.federation.org.directoryServices
      are identical to the working configuration in 12.1.2.4.
  • If I remove the OpenDJ-related settings from
    <HTTPServer>/conf/conf.d/30-app-Windchill-Auth.conf,
    Active Directory authentication works correctly and I can log in.
This suggests that the JNDI adapter configuration is valid, and that the issue is likely related only to authentication order / priority in 13.1.2.0.
■ Request
Has anyone encountered a similar issue where OpenDJ takes authentication priority after upgrading to 13.1.x?
If so, I would greatly appreciate any guidance on how the authentication order can be controlled or corrected in 13.1.2.0.
Thank you in advance for any suggestions.
avillanueva
23-Emerald II
Mar 20, 2026 2:18 PM UTC
Its the order in your 30-app-Windchill-Auth.conf file. Look at how the Location field is being generated for the AuthBasicProvider. You might need to alter the name in the app-Windchill-AuthProvider.conf since I think the script orders them lexographically.
avillanueva
23-Emerald II
RYOFUJITA7-BedrockAuthor
7-Bedrock
Mar 20, 2026 2:30 PM UTC
Thank you very much for your response.
Following your advice, I was able to resolve the issue.
I really appreciate your help.
