Baseline & Managed Collections tables added to Related Objects Tab
My current task is in wc10.
Under the "Related Objects" Tab for many object info/detail pages, I would like to add "Baseline" & "Managed Collections" tables.
Some users have found that they like using the new managed collections area, but would like to see those & baselines in the Related Objects Tab/pane.
In wc9, Baselines used to show ootb for related objects tab/pane. But they took it out & we need it & collections to show.
I went to the customizers guide, but as usual it points to several files. navigation-actions & models & others, but its hard to connect them all up to include collections & baselines tables in the related objects tab/pane/tables
I do know you can now add customized tabs & have drop down selection for related objects & include collections & baselines, but management doesn't want to add a tab, just to include it where they say it should be...in the related objects tab.
I appreciate any help.
thanks
L Jett
