CAD attributes cannot be mapped into part MBA attributes
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.4
Attribute mapping is configured in the CAD document. The attributes in the model can be mapped to the CAD document attributes normally, but cannot be mapped to the parts associated with the CAD document.
What is created on the part is not an IBA attribute, but an MBA attribute. The internal name is consistent with the one in the CAD document.
Translated the text from Chinese to English using google translate.
Subject: CAD属性无法映射到部件MBA属性中
Body: 在CAD文档配置了属性映射,模型中属性可以正常映射到CAD文档属性中,但是无法映射到CAD文档关联的部件中。
部件上创建的不是IBA属性,是MBA属性,内部名称和CAD文档中的一致。
-By community Moderation Team.
Community Moderator
October 20, 2023
Hi JZ_8890563
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
HelesicPetr
Hi @JZ_8890563
The IBA definition has to be done on the CAD Document type and also on the WTPart type
same internal name, same global attribute
Also check your preference configuration
Attributes to be published on Part  * asterisk is default value and it means all defined attributes
PetrH
