CAD Worker Failing on Registering Server SOLVED
Bang Head Here!!!!!!
Gurus, I've just updated my 9.1 M060 to M070 to make the move to Creo 2.0 next week.
We had a CAD publisher, on a seperate server,that was happily working prior to the upgrade and we were advised to update this to Creo View 2.0 M010 adapter and installed Creo 2.0 m020 on the worker server, now its all gone potty.
I've got everything set up and its creating the folders, everything looks like it should work but it seems to hang when trying to register the server for some reason, here is the job summary from publish monitor
27-Sep-2012 14:06:15:Start PublishJob: Assembly-215640a.asm,1.1
27-Sep-2012 14:06:15:"As Stored" Config Spec is available
27-Sep-2012 14:06:15:The EPMDocument As Stored Config Spec was selected as the default
27-Sep-2012 14:06:15:make temp dir C:\ptc\Windchill_9.1\Windchill\temp\pubtemp\publish9211975054782626609.tmp
27-Sep-2012 14:06:15:Start: Assembly-215640a.asm,1.1
27-Sep-2012 14:06:15:Authoring Application: Pro/ENGINEER
27-Sep-2012 14:06:15:empty temp dir: C:\ptc\Windchill_9.1\Windchill\temp\pubtemp\publish9211975054782626609.tmp
27-Sep-2012 14:06:15:Transferring Files to: C:\ptc\Windchill_9.1\Windchill\temp\pubtemp\publish9211975054782626609.tmp
27-Sep-2012 14:06:20:Number of Files (identified to be) Transferred: 174
27-Sep-2012 14:06:20:ProE Asm Conversion
27-Sep-2012 14:06:20:Added request to PROE queue
27-Sep-2012 14:06:21:Job 57 submitted to worker: dekwcworker-PROE:1
27-Sep-2012 14:06:21:LOGID: worker_5.log
27-Sep-2012 14:06:21: Registering Server
And there it sits until I stop the worker agent,
ProEPublish runs fine manually on the worker server so did I miss something or is anyone else having this issue
HelperLog shows: -
[2012-09-2714:05:45]timestampsaddedtologgingfromcommandargument.
[2012-09-2714:05:45]workerhelper-Version:Creo2.0-M010(13.1.10.14)i486_nt
[2012-09-2714:05:45]Connectingtoserver"dekwindchill"onport5600
[2012-09-2714:05:45]Connectionestablished
[2012-09-2714:05:45]Startedworker
[2012-09-2714:05:50]Workerhasconnected.
[2012-09-2714:06:14]Passing$RUN$messagetoworker.
[2012-09-2714:06:14]Receivedworkertimeout:3600.
MonitorLog shows
2012-09-2714:05:44]workermonitor-Version:Creo2.0-M010(13.1.10.14)i486_nt
[2012-09-2714:05:44]Logginglevelsetto0x01.
[2012-09-2714:05:44]Connectingtoserver"dekwindchill"onport5600
[2012-09-2714:05:44]Connectionestablished
[2012-09-2714:05:44]GotINITSUCCESSreply
[2012-09-2714:05:45]Startworkercommand
[2012-09-2714:05:45]WorkerprocessstartedOk.
Worker Log shows: -
Copyright(C)2000-2012PTC.AllRightsReserved.
[2012-09-2714:05:45]StartingProE:proe2pv-Version:parametric2_F000Creo2.0-M010(13.1.10.14)i486_nt
[2012-09-2714:05:50]Connectingtoserver"dekwcworker"onport2402
[2012-09-2714:05:50]Connectionestablished
[2012-09-2714:05:50]RegisteringasWORKER2dekwcworkerPROE
COMPLETE
[2012-09-2714:06:14]Recipefile:C:/ptc/creo_view_adapters/proe_setup/proe2pv.rcp
[2012-09-2714:06:14]Sourcefile:215640a.asm
[2012-09-2714:06:14]Outputfile:C:/ptc/creo_view_adapters/PVtransfer/w1i1j57/215640a_asm.pvs
[2012-09-2714:06:14]RegisteringServer:
