Sep 3, 2015 1:21 PM UTC
Can I use favourites with Desktop Integration through Windows Explorer?
We have multiple documents spread through multiple contexts that we have to use in our day to day work dependent on what task we are performing.   Is there a way to favourite these documents or locations so I can easily access them through Windows Explorer with Desktop Integration?
sm_01Answer
Sep 9, 2015 9:50 PM UTC
Stephen Oerton‌, sure no problem. The following video demonstrates how it would work once the Favorites are created. I am assuming you are referring to the Favorites capability in Windows Explorer. The most consistent way of adding items to the Favorites list is to open %USERPROFILE%/Links in Windows Explorer. Now open a second Windows Explorer Window and use the RMB to drag items into the Links folder. When you drop them, use the "Create shortcuts here" in the context menu.
If you just try to drag items to the Favorites bar in Windows Explorer, it will only let you create shortcuts for locations. When you open the Links folder, you can create a shortcut to anything.
Video Link : 6298
This video clip has no audio.
23-Emerald II
Sep 4, 2015 6:55 PM UTC
Stephen,
I have not had a chance to test this out, but I found a few references in SPRs and cases that seem to indicate that you should be able to add them to your Favorites.
sm_011-VisitorAnswer
Video Link : 6298
soerton12-AmethystAuthor
Sep 14, 2015 2:29 PM UTC
Hello Scott.  This has proven quite helpful.  Thank you
