Cannot start additional MethodServer/BackgroundMethodServer
Hi All,
I am attempting to add additional MethodServers and one
BackgroundMethodServer to an VM running 10.1 M030 under Windows Server 2003
on an ESX cluster. This VM has been cloned from a different cluster and
the WC instance re-hosted by an ant script. As long a single MS is used,
all is well. However, when I attempt to add multiple MS/BMS's, the first
MS starts OK, but any others briefly flash a window and die. No logs are
written for the failed MS/BMS instances. The server manager log shows a
time out and attempts to restart the failed MS/BMS repeatedly.
Interestingly, there appears to be a race condition. If a BMS instance
starts first, the BMS lives and the MS dies. If the MS invokes first, the
BMS, WC comes on up.
I dug through the PTC Knowledge base and saw some similar behavior related
to Java libraries, but in those cases, no MS/BMS seemed to invoke at all.
Has anyone seen anything similar?
Ben
