Change a wt.properties value during rehost
  • August 2, 2012
  • 2478 views
The Rehosting Utility has been built to automatically rehost the most common environment configurations but there may be times when a unique configuration is not updated properly as part of the rehost.  To ensure that a rehost results in a fully functional system, you may need to change property values that were incorrectly set by the utility.  The utility is designed to support this operation via the StartProcessTask.
First, create a script (bat file, shell script, etc.) that makes the proper update via xconfmanager.  The following prop-update.bat runs an xconf command to update the value of wt.server.codebase.
prop-update.bat
set WT_HOME=D:\PTC\Windchill10\Windchill
start %WT_HOME%\bin\xconfmanager -p -t codebase/wt.properties -s "wt.server.codebase=http://master.company.com/Windchill"
Next, create a script entry in rehost.properties that references the script relative to the Rehosting Utility installation directory.  In most cases, placing the scripts in the rehost\scripts directory should be sufficient.
rehost.properties
rehost.script.propfix=..\scripts\prop-update.bat
Lastly, modify projects.properties to run this script immediately prior to starting Windchill.
projects.properties
rehost.modules=IERehostTask,ApacheRehostTask,DBRehostTask, OrgRehostTask, \
StartProcessTask:rehost.script.propfix, StartProcessTask:rehost.script.wcstart, VaultTask
Now, when you execute the Rehosting Utility, the prop-update.bat will be executed as part of the process before starting Windchill.
ejaeger5-Regular MemberAuthor
Not sure why the newline characters aren't rendering properly in the code snippets.  I will fix this soon.
