Change an attribute value depending of the folder
  • May 25, 2012
  • 1653 views
Hi.
Is that possible filter the enumareted values of an Attribute depending of its folder path?
e.g. I have a product called PROD1, and within this product 2 folders FOLDER1 and FOLDER2.
My document type has an attribute called CLASS.
I want that, if I create a document in FOLDER1 the possible values for CLASS attribute are F1-01 or F1-02, and if I create a document in FOLDER2 the possible values are: F2-01 or F2-02.
Was I clear? How can I do this?
Danilo, did you get any info on this?
I'm trying to do the same but based on CONTEXT. http://communities.ptc.com/thread/39041
