11-Garnet
Jul 12, 2021 1:10 PM UTC
Changes to Windchill Performance Advisor from Windchill 12.0.2.0 release.
With the release of Windchill 12.0.2.0, PTC has made some important changes to Windchill Performance Advisor. These changes are described in TS articles here. Please review and send us your comments or questions.
HelesicPetr
Jan 7, 2022 9:14 AM UTC
Does a link work? In my case a warning is shown that alert does not exist anymore.
PetrH
Jan 7, 2022 12:40 PM UTC
I have the same warning.
Jan 10, 2022 12:56 PM UTC
@sgaikwad31
I am currently on 12.0.1.2 and planning to move to 12.0.2 in the next few months.
I turned on PA in our current version but have run into a major problem.
https://community.ptc.com/t5/Windchill/Performance-issue-with-PA-Cannot-set-Location/m-p/754433#M65645
I submitted a case for the issue and they are looking into but.  My concern is as I stated in the case I submitted whether this is still a problem in 12.0.2.  In the post I have asked if anyone is on the version my company is on and has turned on PA but there was no response.
TomU
Jan 10, 2022 1:24 PM UTC
@STEVEG,
We've been on 12.0.2.2 for quite some time and are not seeing any issues related to performance advisor.  The only time we have the spinning wheel that you show is when someone attempts to use the embedded IE browser inside Creo and still has the 'use compatibility mode' turned on.  Once we turn that off and remove the Windchill server from their compatibility list, everything works fine.
HelesicPetr
Jan 10, 2022 1:27 PM UTC
Hi @TomU,
The 'use compatibility mode' is good point.
I always forget to check it :D.
PetrH
11-Garnet
Jan 10, 2022 1:23 PM UTC
The TS article link mentioned above is expired, Here is the correct link
